A little help, reporting mode malfunction
  • A little help, reporting mode malfunction
    Just finished up a good sized program and it is showing me the results when I look at command mode, but when I click over to report mode its just showing the part number and such, no dims.......
    never seen this before so it must be something simple. Ohh version 3.1 thanks
    Do you have your output set to report or both? If it's not either one of these it will not show up in report mode. If that's not it is your edit window layout menu actually set to show the dimensions?
      Most likely the edit window preferences is set to out of tolerance only.
      B&S Global 544
      Using 3.7mr3
      Peace
      Greg
        hmm found it
        Report, Customize, Show Dims......
        Not sure why that happened, thanks though!
          Do you mean 3.08? first version I used...man that's long time ago
          sigpicIt's corona time!
