Does anyone know how to run a macro without hitting the "Play" button? Is there any code or basic script that can run a macro in the middle of a programs execution?
Macro
You'll need to run a .bas. Can you save it as a .bas through something like Excell's VB editor (PCDMIS's sucks)? Or is it a macro that automates? In that case you'll need to write an automation script. What does you macro do?
Here is code for a script that passes a variable to the .bas
Code:CS7 =SCRIPT/FILENAME= C:\COMPORTSCRIPT.BAS FUNCTION/SendToCom,SHOW=YES,COMPORT,FEAT7,, STARTSCRIPT/ ENDSCRIPT/
Here is code without a variable pass:
Code:CS2 =SCRIPT/FILENAME= C:\PCDMISW\BASICUTIL.BAS FUNCTION/Main,SHOW=YES,, STARTSCRIPT/
I've attached the bas file I'm working on now to help you out. What I'm looking for is the code inside the bas file if anyone knows how to do it.
I want to be able to execute my program in PC-DMIS, run a macro I made inside PC-DMIS, and record how long it takes. I've already put in the system start and end times, I just need the macro in between to time how long it takes. I'm doing the test on several different computer systems.Attached Files"Your mom goes to college."
Kip
No. The bas file was for you hoping it will help you pass variables. It's basically just a menu interface that assigns variables back to pc-dmis depending on what you choose.
This is the code I have so far...
Code:ASSIGN/V1 = SYSTEMTIME("hh':'mm':'ss: tt") COMMENT/REPT,"Start time: " + V1 , COMMENT/DOC,******************** ASSIGN/V2 = SYSTEMTIME("hh':'mm':'ss: tt") COMMENT/REPT,"End time: " + V2 , PRINT/REPORT,TO_FILE=ON,AUTO=3,$ TO_PRINTER=OFF,DRAFTMODE=OFF,$ PREVIOUS_RUNS=DELETE_INSTANCES
Kip
OK bear with me I am getting this. Thanks I knew about assignments through automation I was just hoping that you could pass a variable back to PCDMIS without automation as if it were a calling routine so to speak. I know you can't just a pipe dream. I guess I am lost now. If you have written a .bas you can call it with the code I first posted instead of the comment. Then your plan would work. I guess where I'm lost now is why wont it work? Or does this go back to your question about running *.mac? Sorry if I might be wasting your time with my confision at this point dccfreak has been pretty handy with these issues maybe he can chime in sometime.
You're not wasting my time. I appreciate the help.
The problem lies in the macro. In my test I made a macro (*.mac) to rotate the cad, turn the model solid, etc. I'm trying to time how long this takes on different computers in hopes to get an upgrade.
I need some way to have the macro run during the execution of a program (Ctrl + Q). I don't know the code to do it in a *.bas file, and I don't think there's anyting in PC-DMIS that will do it without hitting the "Play" button. I may have to do it in front of some bosses so I wanted to make it look good."Your mom goes to college."
Kip
OK I'm finnaly following you. Neat idea. I went and looked at the macro function and I didn't see anything that I could help you with. I am seeing it the same way as you it is playable only from the toolbar. At first I thought maybe you could use VBs SendKeys function but there is no shortcut key and then you'd have to get around the FileOpen dialog. I'd hate to say it but I can't think of a way to do it but I'm going to check the Basic language reference. I assume you have it but if you dont here it is.
Craig
OK update: I just checked the reference and I don't see anything there either. Sorry about that.<internet bumper sticker goes here>
Does anyone use Basic script, and if so can you help me. It seems as if i've screwed something up. When i put it in my program and change to (loadexcel)...
Channel: DataSuite SPC
04-22-2008, 12:59 PM -
by watc98
I experiment with VB script by insert the beep script to a program:
CS1 =SCRIPT/FILENAME= C:\DOCUMENTS AND SETTINGS\MY DOCUMENTS\BEEPTEST.BAS...-
03-09-2008, 09:40 AM -
by SanderI have this part i would like to put into the end of all our programs.
Is there a more elegant solution to this, like making a single ...-
Channel: PC-DMIS Code Samples
08-10-2017, 07:06 AM -
by kaikaiI am new to PC-DMIS script. I am trying to read the script examples in the “Wizards” folder that comes with the installation. However, they are all...
06-09-2017, 01:44 PM -
by IZAKKI was wondering if anyone could help me out with some instructions or information on how to use VB scripts in a program. Things like how to load or input...
06-09-2008, 11:35 AM -
