V3.7-MR3 BUG~ERROR~ISSUE
Yeah, the answer is to use V3.7, which is what I am using. Since I did the install off the DOWNLOAD of the complete file, the DLL file should be the right one.
Error
I get this same error at times Ver 3.6, but I can't find a common reason for it as you have. I posted this in the other forum and the response I got was from the following link:
http://www.brownandsharpe.com/anyboa...sts/26690.html
I have not tried to fix it yet because I'm not running the programs that gave me that error at this time.
Guest repliedso what you're saying is that there is a 0.00000000000001% chance that you screwed up.
Well, I am using READ POS in a NEW program created in V3.7MR3 because the holes in the part are not even close (not OUR part, outside work I am doing) and I have found a BUG~ERROR~ISSUE with this. IF the read-pos hole (slot, etc.) is the first feature AFTER a tip chage, I get this in the EXECUTE WINDOW:
DOF: M54 INVALID MACHINE NOT IN MANUAL MODE
All you need to is click on CONTINUE and it will keep going, but it sure shouldn't be popping up this error. The program has a manual alignment, 2 DCC alignments, then it goes on from there. All these hole features were created in DCC mode, none in manual mode, so this is a BUG, this is not anything I did (I am about 99.99999999999999% sure of that) and it ONLY happens for a hole (slot) with the READ-POS option immeadiatly after a tip change. If you do a tip change and it measures something else FIRST, then gets to the READ-POS hole, it just keeps right on going.Tags: None
by MordekaiRecently, I've been getting a rash of the following errors on my 9159 and 9129 Xcel Machines during initial probe rotations: DOF: M54 invalid machine...
05-07-2008, 12:41 PM -
by Marc in SWI have a Tesa micro-hite 3D, pcdmis 4.2, sheffield controller. I and doing setup and in the manual mode I want to change the retract. I am using the 1mm(.039)...
03-07-2008, 08:12 AM -
by NevetsI just updated from 3.7 MR2 to 3.7 MR3 and I keep getting an error on the move point after a wrist change. The error is " DOF : M54 invalid machine...
08-06-2007, 01:16 PM -
by Paul SarrachOkay, I have done this a million times but this time ????
Okay, I have three tooling holes, in the first program I would mark all and...-
04-03-2008, 11:03 AM -
by grandpaal56FIRST, I WOULD LIKE TO THANK ALL OF YOU FOR ALL THE USEFULL INFO YOU HAVE GIVEN ME IN THE PAST, WITH THE COMBINATION OF ALL OF YOUR EXPERIENCE, YOU GUYS...
06-03-2008, 11:34 PM -
