Well, I am using READ POS in a NEW program created in V3.7MR3 because the holes in the part are not even close (not OUR part, outside work I am doing) and I have found a BUG~ERROR~ISSUE with this. IF the read-pos hole (slot, etc.) is the first feature AFTER a tip chage, I get this in the EXECUTE WINDOW:
DOF: M54 INVALID MACHINE NOT IN MANUAL MODE
All you need to is click on CONTINUE and it will keep going, but it sure shouldn't be popping up this error. The program has a manual alignment, 2 DCC alignments, then it goes on from there. All these hole features were created in DCC mode, none in manual mode, so this is a BUG, this is not anything I did (I am about 99.99999999999999% sure of that) and it ONLY happens for a hole (slot) with the READ-POS option immeadiatly after a tip change. If you do a tip change and it measures something else FIRST, then gets to the READ-POS hole, it just keeps right on going.
