Well it must be warm here today about every half hour the compresser is shuting down low air pressure so it's hasn't been a very productive day. It's one of those hurry up and wait. Is it warm at your plant? Do any of you have your very own air supply?
TO WARM DOWN AGAIN
I have my own air supply, but I am in a little different situation then you. This is an independent ISO certified lab. We did add a larger storage tank even though we are using a screw compressor, just so we wouldn't over work the compressor. And we installed a small dryer just on the other side of the wall from the machine, this way it gets the dryest possible air. Seems to work well this way and even when we have had these hot hot days we have had no problems.
We're here at 68 degrees, 45% humidity and obviously the airco is holding out. We have no windows and an inside cafetaria. So it's always a surprise to see what kind of weather it is when you get out. At the machine, we can't even hear thunderstorms come by. Light-less and clueless. Just another day like every other one....
Current Conditions
100°Clear
Wind: South 15 mph | Humidity: 39% | Dew Point: 72 | Visibility: 12.0 mile | Barometer: 29.59 | Heatindex 109
Oh, the window unit in my room is working its azz off but it's keeping up. I don't have my own air supply but I have never had any trouble with it.Last edited by Slimvinn; 07-31-2006, 04:27 PM.
Originally posted by Mike N.good thing they don't feed you dung........you would be a mushroomSad isn't it. I certainly feel like a mushroom. Look like one too.
Originally posted by UnderspecDon't buy CMMs that use airWhen in doubt, post code. A second set of eyes might see something you missed.
We just moved into our new facility about 2 weeks ago. The first week the room held 70 deg. and the humidity was 38%. The middle of the last week the humidity jumped to 60% the temp has remained the same. The air vents are pooring water at least twice a day because of the condensation, the tiles around the vents are turning brown. The room is great (1300 Sq ft & 500 sq ft for storage) but we've got to get a dehumidifier or something in here. Any suggestion.I might not love my job, but I love the ones it feeds!
by #2#I have two questions for all you guys and gals with air bearing machines.
Do you shut down your machine(s) overnight or over the weekend....-
08-25-2006, 10:14 AM -
by rsegriggyWe've got a Global 9-12-8. Yesterday, the power failed here. The z-rail came down and the probe hit the granite. There is a battery back-up (appropriately...
07-14-2010, 10:39 AM -
by Kevin Wattsgood morning. i have a good one. i had the luxury of a 5 day weekend and started getting calls on friday about problems with my cmm. operator started...
08-06-2007, 10:48 AM -
by gppcdmisIn the past two weeks my machine just stopped and I heard the air switch on the CMM just shut off and went on with in couple of seconds. I watched the...
03-29-2010, 12:47 PM -
by jaymundayIm using a XCEL 9159. It sat for years before making its way here so Ive had air hose after air hose pop off. I usually reconnect it then zip tie it....
06-16-2012, 09:43 AM -
