Creating analysis to report
  • Creating analysis to report
    I can not get my report to duplicate my analysis window.
    Here is the situation.
    I have measured a series of points around a part.
    I then constructed and profiled 4 feature sets.
    At the analysis window I changed my view.
    At this point all three views had the same image.
    I left the top view the same.
    On the bottom left view I enlarged the left side of the profiles.
    On the bottom right view I enlarged the right side of the profiles.
    I then selected create analysis view command. So far so good.
    However, my report shows the same image in all three views.
    When I F9 my analysis window shows the views I want.
    Does anybody have a solution?
    Any and all help will be greatly appreciated.
    2009mr1
    The representation of the analysis window in reports isn't very good, I believe this is a known issue.
    I'd just do three single analysis views.
    Applications Engineer
    Hexagon UK
      A set is a single point. Profile each point and the analysis all four.
      sigpic GDTPS - 0584
        It would be better if people actually indicated what version they are posing the question in. V3.25 is very different than 2009.
          He did post what version. 2009mr1
            Ah yes. Did not see it with all the other text.
            • AuRules
              Analysis
              by AuRules
              1) Went and measured a circle with ten points.
              2) Then I created a roundness feature from the circle.
              3) The I opened the analysis view....
              10-01-2008, 03:54 PM
            • JackMido
              Analysis View
              by JackMido
              [incoherent ramblings of a man on the edge]
              Does anyone have any tips for getting analysis view to work properly? I'm currently adding the analysis...
              03-01-2018, 10:11 AM
            • TOMW.
              Analysis Window View direction
              by TOMW.
              I'm trying to use the analysis view in the y-axis for circularity analysis on a part I've got
              mounted lengthwise on the cmm table, but the analysis...
              04-07-2015, 02:36 PM
            • cappy6124
              Analysis View is Blurry
              by cappy6124
              Hi all,
              i'm trying to use a graphical analysis to show our polishers where they need to hit a part, unfortunately after the analysis...
              02-29-2012, 10:27 AM
            • sealevel
              feature ID in analysis view?
              by sealevel
              is there a setting to enable the feature ID to show up in an analysis view window in the report?
              i have searched in settings editor, the help file...
              01-20-2011, 08:24 PM
