Can I show print out in report mode or show in the graphics window the IJK of a point other than printing out program?
print IJK vector
Code:COMMENT/REPT,NO,FEAT1.I + "," + FEAT1.J + "," + FEAT1.K
You might be able to do it from the dimension location dialogue but I don't report point data so I have little experience there. If you can't do it as a dimension or don't want to the above code will work.
CraigLast edited by craiger_ny; 07-28-2006, 02:12 PM.<internet bumper sticker goes here>
If you can get it into a variable and you can get the variable into a comment then I don't quite understand what is not working. Are you saying that the comment does not show in the report? If that is the case you need to have your reports display comments (it may be turned off). Also do you have operators in your feature names?
I just ran this code
Code:DTM_A =FEAT/PLANE,RECT,TRIANGLE THEO/1.8821,14.1795,-27.3904,0,0,1 ACTL/1.882,14.1795,-27.3653,-0.0000683,-0.0004152,0.9999999 MEAS/PLANE,4 HIT/BASIC,NORMAL,1.1046,14.8292,-27.39,0,0,1,1.1046,14.8292,-27.3651,USE THEO = YES HIT/BASIC,NORMAL,2.6871,14.8294,-27.3908,0,0,1,2.687,14.8295,-27.365,USE THEO = YES HIT/BASIC,NORMAL,2.6872,13.5299,-27.39,0,0,1,2.6871,13.5299,-27.3655,USE THEO = YES HIT/BASIC,NORMAL,1.0495,13.5297,-27.3908,0,0,1,1.0493,13.5295,-27.3656,USE THEO = YES ENDMEAS/ ASSIGN/AR_IJK = ARRAY(DTM_A.I, DTM_A.J, DTM_A.K) COMMENT/REPT,AR_IJK COMMENT/REPT,DTM_A.I + "," + DTM_A.J + "," + DTM_A.K
Originally posted by Randy POK its Monday I got rid of the NO statement and it works great. Thanks. Not sure which way to go yet, I've got 50 pts to show this on.
Can't you just output "V"?
Code:PNT1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/3060,726.22,619,-0.0185542,0.9997414,-0.0131511 ACTL/3060,726.22,619,-0.0185542,0.9997414,-0.0131511 TARG/3060,726.22,619,-0.0185542,0.9997414,-0.0131511 ACTL_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 15 DIM LOC1= LOCATION OF POINT PNT1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X 3060.000 3060.000 0.000 0.000 0.000 0.000 ----#---- Y 726.220 726.220 0.000 0.000 0.000 0.000 ----#---- Z 619.000 619.000 0.000 0.000 0.000 0.000 ----#---- T 0.000 0.000 0.000 0.000 0.000 0.000 ----#---- V -0.019 1.000 -0.013 END OF DIMENSION LOC1
"Your mom goes to college."
Kip
by knatiHow do I turn off the POINTDATA that is being printed on my inspection report?
12-15-2006, 10:56 AM -
by cjtronettiIn writing a program to send my report to a folder, I've run into a problem redrawing the report. I know that I can "refresh" or "redraw"...
12-06-2013, 11:24 PM -
by nagsveTwo problems using this report:
1.0 - Setting the report to NOT use text mode (right click/use text mode for dimension CHECK BOX UNMARK) I get...-
02-09-2015, 01:49 PM -
by dcossI still can't figure out how to cancel printing. I don't even see anything in the code that says anything about printing, but every time I execute the...
07-17-2018, 07:25 AM -
by cowrevengeHow do I export report comments to excel? Currently it just seems to ignore them.
07-12-2018, 05:15 PM -
