I'm programming a part for one of our subs, and their print calls out PERP. of a plane back to a through hole. Is that odd? I'm used to the through hole having its PERP. called back to a plane. Note the other way around. This is their way of controlling the paralellism of two of the planes.
Does this seem backwards?
Perhaps the face is the moving part and the through hole gets a shaft mounted in it to rotate the whole thing. In that case it would be dimensioned as it is applied. That is the real question, is it dimensioned as it is applied? There is no convention that says you control this to that. How you control your features depends on the parts usage. If the part is to be stationary and a rotating shaft goes through the hole then I'd say yeah it is backwards but if the part gets mounted to a rotating shaft and the entire part moves then you would probably want to control runout of the face and I'd say it is dimensioned smartly. What is the application?
The funny thing is I have no idea what the parts function is! I DO know that the two faces that I am questioning are mount surfaces, and that something (maybe a porpoise or llama) runs through that hole they are supposed to be PERP. to. ****, it's Friday and I'm burnt out.CMM Programmer
Jackson Michigan
Mistral 7.7.5
4.3MR2
Originally posted by Sl33stakThe funny thing is I have no idea what the parts function is! I DO know that the two faces that I am questioning are mount surfaces, and that something (maybe a porpoise or llama) runs through that hole they are supposed to be PERP. to. ****, it's Friday and I'm burnt out.
Since porpoises don't run I'm going to guess a llama!
Here you could use this.
TGIF http://www.pcdmisforum.com/showthread.php?t=1768
by AlexAI want to be able to load a part on a fixture either way up, and the program select the correct cycle based on whether a hole is or isn't present....
05-24-2012, 06:11 AM -
by #2#Hello Everybody
I am having some trouble with findhole in the autocircle window. I brought this up before and never got a satisfactory...-
12-01-2006, 03:44 PM -
by jaymundayYou know how a hole sometime has a feature control frame back to a datum that is the surface the hole is on. Thats prett much perpendicularity correct?...
07-07-2017, 11:27 AM -
by AuRulesTHE ENGINEERS BROUGH ME A PART TO CHECK FOR THEM, IT IS A PIECE OF LANDING GEAR. THE PART IS 8.5' LONG ABOUT 5" TALL AND ABOUT 3 INCHES THICK. IT...
01-29-2007, 09:36 AM -
by ErikirI have a block with a hole through it. When looking through the hole, datums B and C are the sides of the part, and datum A is the top plane of the part,...
11-03-2014, 11:24 AM -
