True position for 4.0
  • True position for 4.0
    Does anyone know or have instruction on how to use the
    true position with the new pc.dmis 4.0 ? The help is actually for pc.dmis
    3.7 .Even the manual for 4.0 does not show on how to use it properly.
    I have not used 4.0, and do not intend to, but I would be surprised if they changed the way you create a dimension with it all that much. I heard they were going to retool the way it used MMC when applied to a Datum, or at least give the user a chance to choose between the way it was done before 3.6 and the way it is now.
    Can you be more specific about what you need help with?
      If you would like the dimensions reported the same way as in 3.7mr3 then go to INSERT>DIMENSION>USE LEGACY DIMENSIONS. This will give you the regular look that I think you want. The new method is a little invovled and would be better explained via compiled document. I will see what kind of time I've got today and see if I can throw something together.
      Right now it's time for a bagel and coffee.
        The Wilcox site has a lab you can pull at the following address
        It's the first download on the list
        I have an additional hand for the use of 4.0 but it's to large to attach. I would be happy to email should you want to get a hold of it.
          Please e-mail your hand-out to me...
          [email protected]
          Thanks for your time.
            Slimvinn,
            That link you have describes the 3.7 methodology. There is a totally new rascal introduced for 4.0 and up. This includes addition of a feature controlframe in your grapghics window and report. Plus TP describes the datum shift used for its computation of bonus, so unfortunately that is not a document for 4.0 and up.
              Originally posted by JamesMannes
              Slimvinn,
              Yeah, but he does say that he is actually 3.7 and depending on your familiarity with the DMIS it has some good info in it. I wanted to attach the pdf but its like 800k which is 4X the allowed.
              I thought he might find it helpful. I should have described it a bit better.
                Even the pdf is bland. The Lab I emailed you and the file on 3.7 were handed out together in order to cover the changes in 4.0.
                It may not be what you guys are looking for.
                  Thanks Slimvinn
                  Rep to you for your assistance!!!
                    Thanks Slimvinn
                    Glad to help
                    The only reason I am succeeding is this forum.
                    Thanks to everyone!
                      Thank you for all your information , I have what I needed to know. IRON MAN
                      you were a great help. Thats what I was looking for; INSERT,DIMENSION,USE
                      LEGACY DIMENSION . Thanks again
