Hello everyone,
I have a Brown & Sharpe MicroVal Pfx with PC-DMIS 3.5 MR2 software and have the following problem. The origins (x axis) of all of my programs seem to shift between 0.2 to 1mm after the DCC alignment, without any change to the fixture or anything else. I’ve even had a shift in the origin (x axis between theoretical and actual results) of 0.3mm with the same work piece that I had re-measured with the same fixture 10 min. later. Other axis deviations are no more than 3-4 microns (mm)! Has anyone had anything similar to this? Is this a mechanical or software problem? Any help would be greatly appreciated!
Thanks in advance.
Best regards
Lepage
Thanks in advance.
Best regards
Lepage
