I have a drawing of a small rectangle piece. The length, width and thickness are all 3 basic dimensions with a callout of Surface Profile of .010 to ALL FACES. How would I go about getting this on the CMM?
Profile - All faces
Tags: None
Originally posted by jkb_mcg View PostI have a drawing of a small rectangle piece. The length, width and thickness are all 3 basic dimensions with a callout of Surface Profile of .010 to ALL FACES. How would I go about getting this on the CMM?sigpic
But how am I to check all these features at one time since its a 2D feature? Just use Vector Points and construct a feature set? I would like to just use calipers and verify the +/- .005 but not sure how to report the actual profile
Originally posted by jkb_mcg View PostBut how am I to check all these features at one time since its a 2D feature? Just use Vector Points and construct a feature set? I would like to just use calipers and verify the +/- .005 but not sure how to report the actual profilesigpic
Sounds like someone has used a profile tol for planar faces.
Just report flatness and position if they are planar.
If not you need a model to work to to compare a feature set to.Roses are red
Violets are glorious
Don't try to sneak up
On Oscar Pistorius.
MIL-TFP-41C
3.7mr3, 2012mr1, 2013mr1
Sorry guys...I'm tied up on another problem...I'll keep checking in on this thread. Thanks for all the input so far.
Originally posted by Obelix View PostIs this just Profile(form) or Profile to datum(form and location)
Funny thing is...it doesn't even have any datum callouts. Its just Profile of .010 "All Surfaces"
by ClementineI am not to familiar with profile callouts on an entire part for tolerances and need help to understand what is needed.
The attached...-
11-08-2012, 02:06 PM -
by hertangelHello.
Can someone help me with ptofile ?? Say, i have total of 16 points. on Z axis .what its the next step how do a group all the points and...-
11-18-2011, 09:18 AM -
by d.evansI have a workpiece with a large area "hogged out" to form sort of a swimming-pool shaped feature set... Several planes, cone-shaped tapered...
04-11-2006, 03:44 PM -
Have a quick question on how PC-DMIS calculates the surface profile dimension. Im am trying to do the profile of a vibra-weld rib on a part, the print...
02-20-2015, 01:11 PM -
by Jan d.Attached please find a sketch of a pocket they want me to measure with a profile called out for all around the pocket. I could evaluate each individual...
07-24-2006, 02:17 PM -
