How do I get the depth of a specified gage diameter from my cone?
Gage diameter depth in a cone
What I have found to be the easiest way is to measure the cone using autofeatures, then go to construct>circle, near the bottom on the left is a radio button for "cone" when you select it the windows ungray and you can choose diameter or height and the info you enter,(either diameter if you need to report distance, or the height if you need to report diameter. The option you choose tells the software which info you are providing), select your cone from the right window and create, then you can dimension the circle you created for either diameter, or distance to datum plane, or z value, etc. Some people do not like the autocone and choose to create a cone from either circles or individual hits. If you do that, you can still use the radio button in the contsruct circle window to get the diameter or height at the height or diameter you specify. I have never had problems with autocone myself. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
- Likes 1
Originally posted by Wes CiscoWhat I have found to be the easiest way is to measure the cone using autofeatures, then go to construct>circle, near the bottom on the left is a radio button for "cone" when you select it the windows ungray and you can choose diameter or height and the info you enter,(either diameter if you need to report distance, or the height if you need to report diameter. The option you choose tells the software which info you are providing), select your cone from the right window and create, then you can dimension the circle you created for either diameter, or distance to datum plane, or z value, etc. Some people do not like the autocone and choose to create a cone from either circles or individual hits. If you do that, you can still use the radio button in the contsruct circle window to get the diameter or height at the height or diameter you specify. I have never had problems with autocone myself. HTH
I cheated a little and created a generic cylinder to the specicifed size then intersected the cone and the cylinder and got the same result as I did with your method.
Thank you Wes.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Thank you Wes.
The instructor told us that cone button was put there just for gage points. It seems a bit cumbersome at first, but after you do it a couple of times, it becomes quick and easy. Kind of like. . . wait, this isn't the off topic zone.Nevermind.
In MM4 there is a gage diameter feature for cones. It will give you the distance from a datum at the specified diameter.
Example: "GAGE_PL1 = DISTANCE/GAGE_DIA; ZXPL, CONE1, 23"
This will give me the distance to a cross section of cone1 where it is Ø 23.
Doesn't PC-Dmis have a similar function?sigpic
Global Advantage 12-22-10
TESASTAR M SP25 4.3mr2
Originally posted by keegoIn MM4 there is a gage diameter feature for cones. It will give you the distance from a datum at the specified diameter.
Doesn't PC-Dmis have a similar function?Last edited by Wes Cisco; 07-26-2006, 10:23 PM.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by DebwhoHI I am trying to find a sharp corner diameter on a cone. I probed the top of the part and set my alignment then i probed the cone so how can I get it...
03-03-2014, 01:10 PM -
by panelbeater1Hi all
Could anyone tell me how to construct a circle at a specific Diameter on a auto cone so I can caulate the height of that circle to...-
10-27-2016, 08:36 AM -
by Kepler67First time Noobie and I could use some advice from the Gurus.
We have an inner cone feature which is measured taking 6 hits at two planes...-
05-29-2008, 04:04 AM -
by Ken8282Good Morning, I am trying to construct a diameter at the top of a cone. I vaguely remember doing it 6 years ago but am at a loss at the moment. I would...
06-24-2014, 11:12 AM -
by PowerJunkieI've got an angled step in the I.D. of a cylinder that I'm trying to measure.
I've tried various methods like probing 3 set's of lines...-
11-09-2007, 05:51 PM -
