What is the MAX on the acceleration? I can't find anywhere where it states this. I want to speed up some programs. I got the movespeed to 100 already.
Acceleration!!
for X, Y, & Z??
Mine came default as X-290, Y-490.5, Z-490.5
Any reason why X would be set to a smaller value?I used to be high on life but I built up a tolerance.
Originally posted by brian Malonemy xcel 12-20-10 is X-175 Y-175 Z-175 strange how we all have different settings. maybe we could do a poll on speed settings.sigpic
Just a scooter pilot
Acceleration
My larger machine works best at x - 200 y - 200 z - 150. I have a tp20 med force with 40x2 tip. It likes to take hits while moving if I make it any higher. Browne and Sharpe said that they couldn't do anymore. When they adjust the belts it helps for a while. One service guy will check them and one won't.
Our smaller CMMs default was 580 for all axis. It will run that fast but it will crash that fast if you make a mistake.
We run at 80% move speed and 2% touch.REVERSE, REVERSE, REVERSE
by dopaliciousI run a Global 09 15 08 pc dmis 2015.1. The max acceleration in X, Y, and Z has somehow been set at 175 for all my programs. Is there a way to change...
04-21-2016, 03:11 PM -
by GomoFazterDoes anyone know if these values need to be matched in some manner? For no reason I always keep them the same and don't know why.
The set of XYZ...-
05-25-2016, 10:38 AM -
by TRD_racingWhat should the max acceleration speed be? My X,Y & Z axises are set at 2500. My machine doesn't seem to be as fast. Just curious. Global Image 9-12-8...
06-01-2006, 12:23 PM -
by DaddyBlutoThis may sound like a n00b question, but is there a way to set what lines show up at the beginning of a program when you start a new program. I have worked...
04-11-2008, 05:23 PM -
What's up Brothers?
I searched the Setting Editor for the Tessellation default to no avail.
Mine is defaulting to .05....-
10-02-2009, 05:37 PM -
