Can two different versions of pcdmis software run on one computer/CMM, if so how can I make them run separately? I am asking this because I have 2 versions on my computer, 3.2063 and 3.07, but when I try to open a 3.07 part program it always tries to open in the 3.2063. Of course I get a prompt telling the program was written in a later version and can not open.
Running 2 different versions of pcdmis on one computer?
It tries to open it in v3.2063 because the program associated with the .PRG extension is the v3.2063 (I guess that version is the one that were latest installed).
You can have them run separately, just take a look at the 'similar threads' at the end of this thread. Not a walk in the park, though - and make sure you have backups if you choose to walk that path...PC-DMIS CAD++ 2o22.2 SP2
Originally posted by vpt.se View PostIt tries to open it in v3.2063 because the program associated with the .PRG extension is the v3.2063 (I guess that version is the one that were latest installed).
Are you sure it's not the other way around? A 3.07 program *should* open fine in v3.2063, since the 3.2063 is later than 3.07?
You can have them run separately, just take a look at the 'similar threads' at the end of this thread. Not a walk in the park, though - and make sure you have backups if you choose to walk that path...sigpic
I had 2 versions on the same pc...........had them in 2 seperate folders.....also had seperate probe files so always had to remember to change edit/search path settings..it can be donesigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by Geister View PostCan two different versions of pcdmis software run on one computer/CMM, if so how can I make them run separately? I am asking this because I have 2 versions on my computer, 3.2063 and 3.07, but when I try to open a 3.07 part program it always tries to open in the 3.2063. Of course I get a prompt telling the program was written in a later version and can not open.
It is not difficult to set up using regedit commands to update the registry before loading the relevant pcdlrn.exe
You must have set up the pcdmis install correctly before installing new versions or this will not work.
It is not quite as straight forward on an ONLINE seat as the registry entries have to be very carefully done so as to not create conflicts with the controller and the different versions.
I do not use multiple versions on the cmms as it isn't necessary.
I can convert any program on my pc and run it offline to see if it works.
There are instructions on how to do multiple installs available if you do a search.
Why do you have 2 versions?
If its on a live cmm one version is all you need.
Im stuck with 5 because i have 10 cmms in the factory with everything from v3.5 to 2009mr1 (new cmm) and the bean counters wont let me upgrade the old ones. There are also 4 MM4 seats and 3 Quindos 6 seats.
Try keeping track of that lot!!!Roses are red
Violets are glorious
Don't try to sneak up
On Oscar Pistorius.
MIL-TFP-41C
3.7mr3, 2012mr1, 2013mr1
by Carl Winsettwhen trying to open a program I get a serialization error and the prog. will not open. Is there a way around this? What can be done?
10-02-2007, 01:41 PM -
by Giovannid10Se-10sre_rear. Prg-Serialiazation error error_alt
Has anyone ever recieved this message if so What does it mean????-
07-16-2008, 05:29 PM -
by pgvsmitopen pc-dmis in online admin mode
"Open" greyed out. Cannot even open programs in the recent menu.
Also will not...-
12-23-2021, 09:39 AM -
by mattfurtawI had not run this program in quite some time and today when I went to open this up an error window poped up. I have never seen this before and it won't...
09-19-2007, 10:33 AM -
by ChannyHi All,
I don't know what has happened but my version of PC-DMIS has suddenly started crashing every time I try to open a program....-
05-09-2019, 06:55 AM -
