New Computer
  • New Computer
    Hi , I am getting a new computer today and would like to know how to get my IP address information.
    I have a global Image with a PH10M and a SP600 head.
    Currently running V-3.5 with NT and will be going to XP professional.
    Any advise is welcome.
    Thanks, Sean
    at a command prompt C:\
    type ipconfig
    do this in a DOS window listed under start/programs/accesories
    this will give you the networked pc info but NOT the controller IP address
    this I'm not sure how to get.....I think its in the hyperterminal area
      to get to a dos window just goto START, and RUN, then type in CMD
      Then do what Mike said.
        Controller IP
        To get the controller IP information, you could just look at what the old computer was using for PC-DMIS. This is in the Machine Interface area, if you are using TCP/IP connection.
        Other than that youo need to go to terminal mode and enter the command SHOW CNTRLR_IP for the controller and SHOW HOST_IP for the computer. I believe the spelling is correct, might be CTRLR_IP or similar).
          Thanks for the help !
          I got the IP info. This forum is great.
