I had some strange things happen yesterday and I'm curious if anyone else has run into this.
I was manually adding a feature to a program that has successfully run for quite some time and found that once the feature was entered, the program would bomb giving me a "lag in y axis" error when doing a rapid movement to the feature. I removed the feature and move points that had been added, shut off the Sharpe32 controller and PC, and rebooted to find that when I tried to enter the feature again that the hits would register in the graphics display, but hitting "enter" on the keyboard of "done" on the jogbox did nothing. I could not enter the feature into the program and also at the same time, I could not enter a "move point" from the print key on the jogbox. After several attempts to resolve the problem I shut everything down and figured I'd work on it when I had more time.
Four hours later when I fired up the CMM again, I found that it had miraculously healed itself and I could now enter the feature and move points and the program executed flawlessly.
We are running 3.5mr2 on a new computer that has more than enough memory and graphics, but we switched from Windows NT to XP Pro. Is it possible that XP is the culprit?
