Pictures for Probe Configurations
  • Pictures for Probe Configurations
    Is it possible to link a picture to a probe configuration?
    I know that for experienced operators, you can pull up the calibrate probe window and see a graphic of what it should look like.
    Is there a way to take a picture and attach it somehow to the probe file so that the picture of the probe is available in all the programs that the probe is used? Otherwise, I'll have to go to each program, see what probe is used & then embed the picture into the program.
    Is this possible? Does anybody else see any value in this or do you have a better solution?
    To some the glass is half full
    To some it is half empty
    To me it is poorly designed by the Eng & Prod wants me to find a way to measure it in spec!
    I've never heard of anything like that.
      To be honest with ya I see no purpose in that....unless your constantly deleting probe files......I mean you open a program, put your cursor in the probe file, hit F9 & you see everything you need in about 2 seconds time....
        Why?
        Steven69
          What is wrong with a written description in an operator comment?
          IE:
          Probe: 50 ext, TP20, 20 ext, 3x20
          Lately, it occurs to me
          2017 R1 (Offline programming)
            It is possable if u want to do it do you have micrsoft word on the cpu
              IE:
              +1
              yeah and a picture doesn't describe what it consists of if you need to build it anyway
              don't forget if you make it too easy for the newb's they will replace you with some dolt who will say "see this is easy, anyone can do it"
                The problem is when you've got to build probes specific to a program & you don't have enough TP20s to go around. For me, it is not a problem. We have others here who don't understand as well. If they had to try to figure out how to build a probe without a picture, it could be a catastrophe.
                There are instances where the probe builder does not have the exact item on the pick list. For example, there is no 50mm_CF extension in the list. You have to build using a 20 & a 30.
                  Probe Utilities – double click on “TP20 module” – click on “Draw this component” check box.
                  View setup – check “solid box”
                  Operation – Graphics display window – check “Center Probe”.
                  HTH
                    ^^^This must not be on 4.2mr1^^^
                      It could be as simple as calling up a picture using object or a form before the loadprobe.
                      --Brian
                      "The best way to predict the future is invent it. This includes your very next action."
                      Support: Hexagon Metrology Support Center
                      Training: Hexagon Metrology University
                        There is no need to write it down. once you higlight a probe, the configuration is already there at the bottom. To see the complete picture, all is needed is to check each component and there you have the whole picture.It not only shows the length and components, but also the orientation at that angle.
                          Thank you guys for your answers but
                          I want the picture linked to the prb file so I don't have to open each program and put a picture / link. That would take way too much time.
                          We have operators who are not very experienced. Also, there are items we use that are not included in the pick list. We use a 50mm carbon fibre extension which is not in the pick list. We have to build the probe using 20mm + 30mm extensions. If an operator looked at the probe build, they would build it wrong. I'd rather have 1 extension than two; less to leave too loose or overtighten & strip.
                            Is this what your looking for I insert/report command/external object/microsoft word picture. Then setup the picture as you like and that should do it. I will rarely put the picture in my programs but, whenever I use a star probe I use the comment below the picture to explain the way the probe is built. And if your good with the probe.dat file you can make the 50mm extentions and other probes. The pictures were captured using hypersnap I'm not sure if that's on all windows computers I know its on all of ours here at work.
                              I have this in each of my program with a external command and a comment to open the picture are not.
