Stats count..
  • Stats count..
    Hello everyone...
    How do You turn on Stats count in 4.0 ??
    Thanks... Len
    You need to have a STATS command which turns on stats saving.
      Insert -> Statistics Command -> Statistics (at least this is what it is in 3.7mr2) ? ? ?
      PCDMIS 2012
      Windows Office XP
        Thanks...
        I don't think I have it in 4.0 Anyone else have an idea?
          If you were running statistics previously, just copy the stats code from an old program and paste into the Ver 4.0 program.
            You might have the same problem as me:
            We use in our partprograms SPC-Database as command to activate the
            StatsCount for each program-run. This functioned prior to 4.x!
            Since 4.0 the use of SPC-Database is removed (as stated in the ReadMe-file),
            so StatCount doesn't work for me like the way before!
            • inspector212
              STATS/ON, but not sending stats
              by inspector212
              I've seen this twice now. The stats code is in the program but the stats (XSTATS11.tmp) do not send to the PC-DMIS folder. The PCs were restarted but...
              05-30-2008, 01:39 PM
            • gitalife
              Stats Count
              by gitalife
              Hello all,
              What is the definition of Stats Count in the header and
              what is it used for?
              Couldn't find anything in the reference...
              10-14-2022, 11:13 PM
            • Jonathan S
              Trace field for stats
              by Jonathan S
              Does trace field need to follow the stats command? Does it need to be inserted between STATS/ON and STATS/END?
              07-29-2008, 08:53 AM
            • AuRules
              Stats
              by AuRules
              I have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems...
              04-02-2007, 09:36 AM
            • AuRules
              Stats
              by AuRules
              04-02-2007, 09:37 AM
