The question is how do I know error map or whatever settings needed are being used correctly? and how do I fix? The difference isn't huge but enough where I don't think something is correct. Probably going to stick with v3.7 for a while but that is the one where the ring gage reads off by .0003.
PCDMIS CAD++ PH10T TP20 B&S 7.7.5; checking program is very simple plane, id alignment done manually and then DCC so I doubt if it's anything with program.
