We got a new CMM and installed V4.0. All previous programs were done in 3.7. We have parts that I measured using the Square Slot function and they are on an Angle, not 90,90. When it goes to measure them it does not measure it correctly. Is there a way to get it to measure correct so I do not have to take points to get the center of the slot, or does the square slot function not work.
PC-DMIS 4.0
Did your hit vectors change when you opened up the program in 4.0? Hopefully you have a copy and still have 3.7 loaded--if so, check and make sure that all nominals/vectors etc. are the same. Start with the basics, and if nothing has changed, then I would suspect maybe something's not right with 4.0? The bad news is, that I have not heard good things on 4.0 so it would not surprise me if that's where your problem is.
Hopefully one of the gurus here will know a little more, but I think it would also help to know machine type, probe type etc....
Tim,
I won't be able to work with that particular problem until later in the week. I know that doesn't help you but that's the best I can do. I would say that I probably will find the same thing as you though. Have you reported this to BNS yet? If not I would at least it may be fixed by 4.2?sigpic
by Marty Schwabhas any 1 tried 4.0 yet i did this fine morning and i could not get the toolbars to work right i would change them and adding buttons and deleting buttons...
03-13-2006, 12:46 PM -
by parrottkI just recieved 4.0 in the mail.
I have not dared to install it yet.
any info or warnings out there.
I am currently running 3.7 MR2...-
05-22-2006, 03:57 PM -
by Dick HelmUsing 3.7, mr3 but I have had 4.0 in the drawer for a year. Should I load it?
11-13-2007, 11:14 AM -
by DuckhunterDont know if you guys looked today, but 4.0 was released.....Anyone thinking of changing right away????
Tim-
03-06-2006, 05:39 PM -
