I am runing 3.7 ,I have a slot checked with the following results, True Position is required for this slot, my boss insist that the true position for this slot will be within spec,
GD&T ON THE BLUE PRINT CALLES: on length 44.25mm. / loc. / 2.0/A/B M / C M/
: on width 17.82mm./loc./2.00/A/B M/C M /
BOTH B & C in max. material condition
X 3670.737 1.000 1.000 3671.699 0.962 0.000 --------#
Y -572.777 1.000 1.000 -571.891 0.886 0.000 --------#
Z 1748.644 1.000 1.000 1748.684 0.040 0.000 ----#----
D 17.820 1.000 1.000 17.962 0.142 0.000 -----#---
L 44.250 1.000 1.000 44.346 0.096 0.000 ----#----
would you please, show me how to fill up TRUE POSITION FEATURE WINDOW.
WICH FEATURE TO BE CHECKED IN THE FOLLOWING :
IN AXIS : FORM OR PRAD - - - - - - ?
IN TOL. BESIDE ENTERING THE +1 , -1 WHAT AXES . DF , ALL , D1 D2 -------?
MATERIAL CONDITION : CHECK MARK FOR USE DATUM
DEVIATION : -----------?
FOR AXIS FEATURES ------?
DIM. INFOR --------?
ANALYS ------ON OR OFF ------?
Please, explaine as for a bigner ?
Thank you in advance,
