Profile/Surface - Help!
  • Profile/Surface - Help!
    See attached. What is the best way to measure the profile callout with PC-Dmis? A circle? Scan? Constructed Curve? Constructed Line? I've tried all of these and getting nothing that makes sense.
    Thanks!
    Global Advantage 12-22-10
    TESASTAR M SP25 4.3mr2
    Individual points, probably vector points. Report "T" value.
      Translate to the center of rad. using bsc. dim's then use vector points and report the dev.
        Another method.
        Measure points on each of the 4 sides.
        MEasure points along Radius (Set origin offset so that center of Radius is (0,0))
        Create feature set.
        Dimension Profile of feature set.
        If you need picture, Insert/Report/Analysis
          i was gonna suggest a circle scan but it looks like you guys got it covered.........
          Originally posted by Ironhoe
          I got something under my sporran for you, take care of it and you got my vote.
            You don't even have to mess with vectors if you move to the radius centerline, then rotate your coordinate system and move straight in along whichever axis you want to measure to: -1,0,0 or 0,-1,0 (XYPL)
            Measure, rotate, measure, rotate........
              This.
              Or, if you have CAD, just set origin at intersection of A and B and create a feature set.
              Report profile/surface Formandlocation +/-.2
              Lately, it occurs to me
              2017 R1 (Offline programming)
                Originally posted by John Riggins View Post
                This.
                Just a question ..... Could you measure a series of points around the radius, create a feature set, create a best fit 3D alignment to the feature set then report profile/surface formandlocation +/-0.2
                It goes "dink" so it must be workin'
                Bollocks
                  I would say no.
                  Your origin and orientation needs to come from the intersection of A and B.
                  The bestfit would negate this.
                    You'd lose your relationship to the datums.
                      Yes ... My Bad .... It does reference A and B .... It's just that I had / have a IMO incorrectly dimensioned drawing which indicates Form and Location as it references datums, but in reality the ungineers want form only ... but still want a +/- tol applying.
                      Hence the 3D best fit I did in my particular case
                      Bollocks
                        Scan it and then report profile (form and location) back to AB.
                          yeah, and I told you how to do that, didn't I.
                          I was gonna post that the best-fit was not correct in this case, but "them" showed up and I ahd to show "them" what they screwed up today and I just got back here to tell you how YOU screwed up today.
                            Can I dimension a scan with constructing something from it?
                              Hey Keego.
                              Have you got CAD++ ?
