Question about theoreticals
  • Question about theoreticals
    This is my 1st post so be gentle please.
    I have been attempring to run some programs that were written by another individual and have a question about the THEO numbers. If you change the THEO to a variable such as PNT1.X+2.5 does this change the nominal in my report each time I run the program based on the actual of PNT1?
    Here is an example of the code in the program...
    LGRFSPT009 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/5603.02,362.61,953.38,-0.9985262,-0.0372399,0.0394798
    ACTL/5602.532,362.592,953.399,-0.9985262,-0.0372399,0.0394798
    TARG/5603.02,362.61,953.38,-0.9985262,-0.0372399,0.0394798
    THEO_THICKNESS = 0,RECT,SNAP = YES,$
    AUTO MOVE = BOTH,DISTANCE = 5
    MOVE/POINT,NORMAL,5591.451,362.424,949.169
    LGRUSPT010 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
    THEO/LGRFSPT009.X+2.22,362.67,949.47,0.0941705,-0.00153,-0.9955549
    ACTL/5604.765,362.67,949.331,0.0941705,-0.00153,-0.9955549
    TARG/LGRFSPT009.X+2.22,362.67,949.47,0.0941705,-0.00153,-0.9955549
    Thanks
    Tom
    I would think that only if you change the nominal in the dimension being reported would it change or if after you change the theo, there is a prompt to change the nom in related features, if you select ok it could change the nom value reported. But i don't think that just changing the theo to a var would do that, unless as i said you select that option to update related nominals from a pop up after you change the theo.
    Life's tough, but it's even tougher if you're stupid.
      What Izzak said.
      Is this for checking trim edges?
      sigpicIt's corona time!
        Originally posted by Roberto View Post
        What Izzak said.
        Yes, that is the intention, but there seems to be some difference in the nominal of the report compared to the nominal of the CAD model. I am just attempting to figure out where that difference is coming from. I am starting to change the program to use the EDGE point with surface and edge sampling
        Tom
          Is the CAD or the PRINT master? You need to find out which takes precedence for this product. Some companies say print, some say CAD. Perhaps he adjusted the nominals in the report for this reason. Maybe the CAD data was not correct, or maybe the parts were wrong, but the decision was made that it was not economically feasible to correct them.
            Hard to think of a legit reason for that other than just plain ignorance OR they have a level of Pcdmis that does not include EDGE point, which has a "built in" function that will bypass the need to do what it appears to have been done.
              OR MAYBE someone ordered him to "sanitize" the report?!?!?!?!?!? I've been asked to do this but refused until my job was at risk, at which time I cleaned up the report but refused to sign off on it and began a search for a new job!
              Bill
                People do this all the time when they haven't been to training and don't realize that edge point and RMEAS exist. It works fine, and falls under the "many tools in the toolbox" but is kind of like using vice grips to tighten your shift knob. Unnecessary.
                --Brian
                "The best way to predict the future is invent it. This includes your very next action."
                Support: Hexagon Metrology Support Center
                Training: Hexagon Metrology University
                  Unless the individual who originally wrote the program had no Cad ++
                    I guess that my question should have been centered more around how PC DMIS uses the THEO and whether it automatically updates the report nominals every time you run the program.
                    It seems to me that it would have been reasonable to use the variable in the TARGET area to accomplish his objective. Just not sure of the ramifications of using variables in the THEO.
                    We have the EDGE function and the program was written with CAD++
                    Tom
                      If the EDGE function was already available, as was CAD++, it looks to me like someone was trying to get fancy for no reason, or were they trying to compensate for possible extra machine stock?
                        These are injection molded plastic parts, no machining involved. I don't think there is anything underhanded going on, just want to understand what might be happening. I thought that by posting here it might save me some time as I wouldn't have to try to prove/disprove whether the nominals change or not.
                        Tom
