90 Degree Probe Tip
  • 90 Degree Probe Tip
    How can one utilize a 90 degree Probe Tip and calibrate. It would be like having only one tip attached to the star Probe Body at 90 degrees with the other 4 tips removed from the star probe body.
    Help!!!!!!!! Any help would be appreciated.
    Thanks Gary
    sigpicThanks a Millionth
    I take it you cannot get to the feature with a A90B0 or with the other styli on the probe body.
    Kevin
      That is exactly the way to build the probe.
      Extension
      Star tip 4 or 5 way
      tip in one position
      leave the other positions empty
      Should calibrate just fine.
      Attached is a copy of one of mine. HTH
      [IMG]file:///C:/DOCUME%7E1/gcisco/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
        Just to remind
        1 ->DOWN
        2 ->RIGHT
        3 ->BACK
        4 ->LEFT
        5 ->RIGHT
        hth
        Either seem as you are or be as you seem.M.J.Rumi
          Originally posted by Saliha
          Just to remind
          1 ->DOWN
          2 ->RIGHT
          3 ->BACK
          4 ->LEFT
          5 ->RIGHT
          hth
          I know things are different over there, but here we only have one "right" and we also have a "front" you seem to be missing. But it is a good idea to make yourself a diagram of your star probe and label the tips, especially if you will be rotating the wrist.
            You are RIGHT Wes , but it is 00:15AM here.
            From the front side of the machine : (Vertical Arm-Bridge Type CMM)
            1-> DOWN
            2-> RIGHT
            3-> BACK
            4-> LEFT
            5-> FRONT
              Most important tip of the day was Wes's tip on making yourself a diagram.
              I did this thankfully, with our star probe--helped tremendously when I had to rotate to 4 different angles. Even then I was upside down trying to figure out what tip was what......
                Extension
                Star tip 4 or 5 way
                tip in one position
                Thanks A Mil ~ I have been enlightened ~ You are God of Pcdmis
                  You are very welcome, but I would rather be a wizard than a God. LOL Nothing against anyone's God. I just don't think I am up to shouldering all that responsibility.
                    You just want to be Gandalf. Wand envy thing.
                      Or Merlin,
                      or Chrestomanci,
                      or Prospero,
                      or Tim the Enchanter,
                      or any one of many.
                      But not that phony from Kansas with the big balloon. I may be a lot of things, but a "pretender" is not one of them.
                      And not Randall Flagg, because I am just not *that* evil.
                      And it is not wand envy, but rather a poor coping strategy for dealing with modern civilization thru voluntary indulgence in escapist daydreams fueled by film and fiction.
                      • Mikielives
                        Adding angles to a star probe
                        by Mikielives
                        I have placed a star tip on our Gage 200 CMM with Pc-Dmis version 2.3 software, this is a manual machine. I have the probe and tip described in the utilities...
                        10-19-2009, 03:42 PM
                      • csshaffer
                        Probe building
                        by csshaffer
                        I am attempting to build a probe tip but I cannot find the fixed portion of the star probe. What I am building is a tesa extended force with a 90 mm carbon...
                        03-21-2011, 01:07 PM
                      • doo_hicky
                        Star probes
                        by doo_hicky
                        Ok, I just spent the whole day building up a star probe. I had to make the changes to specific portions in the .DAT file to make the build up look like...
                        06-03-2008, 02:04 PM
                      • Nfisk
                        Useing the Star Probe
                        by Nfisk
                        I would like to use the star probe, but I am haveing problems with it reading properly if I use any tip other than the tip that is pointing straight down....
                        03-07-2008, 11:56 AM
                      • NMC_CMM
                        Star Probe - select which probe?
                        by NMC_CMM
                        Hey all,
                        I'm getting ready to use a star probe on our TP-200 machine and I was curious to know how PC-Dmis selects which point of the star...
                        05-21-2012, 05:30 PM
