My CMM (B&S Xcel) has started squeeking. It is kind of a squeek, kind of a screech, kind of a ringing sound. It happens sometimes when moving in the ±X axis.
I pulled the shroud off of the back of the bridge. It doesn't look like any of the air bearing ways have been rubbed. I wonder if it might be the drive rack. There is a tensioner on the non-geared side of the rack. I wonder if that is what causes the squeek. It looks like that side of the rack has been rubbed.
Our MicroXcel 7-10-5 has had an occasional squeek in the Y axis since it was purchased new back in the late 90's. The service people who have calibrated and repaired it over the years say it is no problem.
My Excell does too
mine is the covers
B&S adjusted it after a calibration
a month later it started again
if you turn the radio up it goes away
what noise
I have a global Image (only 3 yrs old) and have had to replace the gear and belt once. Now it needs to be done again. It is the X axis also. You may want to look at that.
I have a issue with a global image 5-7-5 running V3.7 MR2. About a year ago the Z-Axis started vibrating during movement up & down. As this was happening...
Ever since we got our new Global back in August '08, I've had problems with this accordion cover getting all messed up. It won't float freely. It gets...
Why do I get these? When I began working on this program, it started happening while changing probes at the probe changer. Now it's happening during...
