I got casting part to measure profile at on Edge of thickness about 5 mm. I tried to use open line scaning and the select the surfaces on the edge (Edge is a winding edge which inclued different surfaces because of curves). I select the starting point on begining of the first surface and direction point at end of the first suface and I add few more points to select atleast two points on each surface then generate the scan but it shows error "can't find part" and generate path does not go thru all the way. Can any one help me?
Thanks.
Mansukh
Thanks.
Mansukh
