Avoidance moves and auto features
  • Avoidance moves and auto features
    Hmm, busy one today for me, 2nd thread of the day.
    Am I doing something wrong, or does PC-DMIS get confused with a move point immediately following an auto measured feature with avoidance moves included.
    Current example. I have probed an internal cylinder via auto feature, and included before and after avoidance moves, I've then added a move point to take probe over a higher area of the job. But, as usual, the auto feature seems to suck the move point into itself and sort of include it as part of that feature, so that it completes the cylinder OK, then goes to the move point, but then goes back again to the avoidance position. This always happens to me. Is it me, or a glitch in the software. It's no big deal for me to bin the 'after' avoidance move and just use a move point to clear, but I'd just like to know if I'm doing it wrong or not?
    Cheers fellas
    Cheers fellas
    Sounds like a "NEW ENHANCEMENT" to me, if what you have described is correct. I'm using V3.7 and the "AUTOMOVE" (avoidance move in V4 because some new coder at wilcox likes the flavor of his own crap better than the taste of the crap from the coder before him) is part OF the feature, any MOVE points (incremental, absolute, clearance plane) programmed after the feature run AFTER the feature is done.
      How about simply not using the avoidance move function and stick with old fashined move-to commands ?
        +1 yes old fashion!!!
          Do you have a clearance plane set? It could be going to the move point, then to a clearance plane if you have one set.
          Bill
            Thanks guys
            Hmmm clearance plane, hadn't checked that. I'm still very much a beginner, so I expect I'll miss the bloody obvious frequently. I've run out of time today, but I'll check that tomorrow and post back.
            Cheers
              Thanks guys
              Cheers
              clear planes & move points do not like each other.....what kind of pickles are you checking
                Sorry for slow reply gents, not been near the evil CMM for a while, been busy on my day job. Anyway, have checked and clearance planes are NOT active, so I'm guessing that PCDMIS 4.3, just doesn't like mixing avoidance moves with move points. That's a shame, because I like the avoidance moves, they are quite nifty for a newbie like me. I can still use 'em, I just have to remember to not use 'em immediately prior to a move point.
                  Inserting Move Points Between Auto Feature Hits
                  You can insert MOVE/POINT commands between auto features' HIT/BASIC commands. You will need to use the Insert | Move | Move Point menu item to do this. Copying and pasting this command will not work. The Edit window must also be in Command mode.
                  Just a thought
                    Thanks PCDEMON, that's not my problem though but still useful to know. The issue I'm getting is when I create a move point immediately following an auto feature that is utilising avoidance moves, PCDMIS seems to see the move points as a part of the auto cycle, and goes to the avoidance point, then the move point, then back to the avoidance point again. Weird, or I'm not doing it right, one or the other.
                    No big deal, as mentioned above, I can program just using move points and NOT avoidance moves, I was just wondering if it was something I was doing wrong.
                    Cheers
                      Just a thought
                      i don't think this is correct?
                      i can insert move points in v4.2 between autofeatures & i don't have to be in command mode. so i would of thought the same of v4.3?
                      if i'm wrong, why has it changed for v4.3? surely thats a backward step.
                      sigpicRichie the Villian!!
                      V4.2 MR1 CAD++/MISTRAL 10-07-07 DCC/XP
                        check help file on move points thats where the info came from .Hope help file is up to date with 4.3
                          I don't think it is anything you are doing wrong Pickle .... I had a similar (note similar but not the same) problem with V4.2 where the probe paths get screwed if using avoidance moves with stud measurements
                          It goes "dink" so it must be workin'
                          Bollocks
                            checked the help file under 'inserting move points' & there's nothing in there about having to be in 'command mode' to insert 1.
                            but as i said, i'm using v4.2, so it could of altered for v4.3 onwards?
                              RCW, I think you're missing the fact that he's saying you can now insert MOVE/POINT command WITHIN the autofeature MEAS , END_MEAS block. Can insert MOVE/CLEARPLANE as well.
