I'm having to manually scan some features on a part. When I export to an IGES file, the feature that I scanned comes out as points. How can I fix this?
Manual TTP Scanning & Export
Thanks Matt. Also would anyone know why my export CAD IGES file would measure out different on a CAD Program than PCDMIS??I used to be high on life but I built up a tolerance.
It's default at startup but I changed it to the last alignment, which is where I wanted it.
But it seems it wasn't my fault at all. It was the CAD guy who picked the wrong features for dimensioning on the CAD file. Yay!
by Ken8282Can you export data you get from a linear open scan as a DXF file? If so how would it be done?
10-16-2012, 12:13 PM -
by eacostaHow can I made that a certain program export to vdaf automatically?
using v3.7mr3-
12-12-2007, 10:02 AM -
by Marc in SWI have an Xcel 7107 with Pcdmis version 2014 CAD++, LSP-X1 scanning probe. The Pcdmis version is 2014. I have a CAD model and I am scanning sections of...
06-07-2018, 01:06 PM -
by Paul SarrachHow do you export a scan? What alignment? If you export it in part alignment and the you import it back in it will not match. But if you export it...
12-19-2007, 11:44 AM -
by KBeardenNo problem exporting scanned items, but when I change the scans to points is when I run into trouble. I have tried several different ways of exporting...
11-09-2006, 08:57 AM -
