IGES solid output
IGES solid output
New user, first time posting but always seem to be very helpful answers here - trying to output CAD model in IGES format for use in Solidworks. Only getting features that were measured to output. Lost original file that was imported to do program. Using V4. Thanks.
using V3.7MR3Tags: None
Lost the original file that was imported? You mean, IGES? It isn't lost, you imported it. Simply import that file as well in Solidworks as well as the measured results. Pcdmis is NOT a cad system, it is a measurement system that uses cad data. You can not alter cad data in Pcdmis, then export it (alter=change levels, colors, alignment, etc.).sigpic
still confused
The original IGES cannot be found on the harddrive; it was imported it off a zipstick so I probably never put it on the hardrive. Since PCDMIS converts it to .CAD for its purposes, I was trying to export it as IGES but only got the measured features (no solid). So PCDMIS won't export anything but what is measured?using V3.7MR3
by W0QNXThey want to "prove out" the conversion process between me importing an IGES made in Catia and what PCDMIS makes.
I can't get...-
10-08-2009, 02:18 PM -
by jonasI made an iges file in solidworks of a solidworks model, when I import the model into pcdmis the iges model has edges to it instead of round radiused...
09-25-2009, 01:42 PM -
by macostaI imported a .step file into pcdmis now i want to exported as an .iges file but its not working.. am i missing something? any input would be helpful.
01-19-2012, 08:42 AM -
by Clay_ManHi all
PC_DMIS 3.7MR2
This is my frist time I have had to uot-put an iges file, and was wondering what was out-putted all features or can...-
05-11-2006, 12:20 PM -
by KennyDI'm running 3.5 and I have taken a large number of features and points (point clouds) on a part that we are trying to reverse engineer. How do I export...
12-16-2010, 07:38 AM -
