Is it possible to use an Assgined Variable as one of the values for a Constructed generic feature? And if so how do you do it?
F2_900_DIA =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/0,0,1.8,0,0,-1,2.9035 ACTL/-0.0014,0.0008,1.8013,0,0,1,2.9042 MEAS/CIRCLE,8,WORKPLANE HIT/BASIC,0,1.4517,1.8,0,-1,0,-0.0004,1.4527,1.8011 HIT/BASIC,1.0265,1.0265,1.8,-0.7071068,-0.7071068,0,1.0273,1.0261,1.8012 HIT/BASIC,1.4517,0,1.8,-1,0,0,1.4506,0.0006,1.8014 HIT/BASIC,1.0265,-1.0265,1.8,-0.7071068,0.7071068,0,1.0263,-1.0247,1.8015 HIT/BASIC,0,-1.4517,1.8,0,1,0,-0.0009,-1.4513,1.8015 HIT/BASIC,-1.0265,-1.0265,1.8,0.7071068,0.7071068,0,-1.0276,-1.0266,1.8014 HIT/BASIC,-1.4517,0,1.8,1,0,0,-1.4536,-0.0009,1.8012 HIT/BASIC,-1.0265,1.0265,1.8,0.7071068,-0.7071068,0,-1.0284,1.0271,1.8011 ENDMEAS/ ASSIGN/F2900DIA = F2_900_DIA.D GENERIC =GENERIC/POINT,DEPENDENT,RECT,$ NOM/XYZ,2.9035,0,1.389,$ MEAS/XYZ,F2900DIA,0,1.389,$ NOM/IJK,0,0,1,$ MEAS/IJK,0,0,1 DIM GENERIC_DIMENSION= LOCATION OF POINT GENERIC UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX MEAS NOMINAL +TOL -TOL DEV OUTTOL X 2.9042 2.9035 0.0050 0.0050 0.0007 0.0000 -----#--- END OF DIMENSION GENERIC_DIMENSION
