Scan probe compensation failed
  • Scan probe compensation failed
    I use an XCEL 7-10-7 machine with PH10MQ probe head and PCDMIS ++CAD 3.7 MR2.
    Scan type: Variable Linear open, Patch Variable.
    Error message:
    Scan probe compensation failed!
    Are there specific settings in the scan SETUP window I should have to avoid this error?
    This scan does not have CAD.
    Thanks!
    Heriberto
    Heri
    scan comp.
    Usually the only time that i have this issue is when the scan is very short..only a few points.
    Are you using a SP600? TP20 on learn mode???
    Tim
      I using TP200. on learn mode.
      Heri
