At my shop we have 2 cmm B&S global image 3.7 mr2, the other is B&S but is down. My question is can the global be used to measure without writing a program to do so. When we first got the Global the techie who came in had us measure stuff with out programing. Not having used the global for several years I have know clue how this is done, our tool inspector may need to measure on the global but has no programing knowledge and needs to use the cmm very seldom. I guess in a very long and confusing way I am asking is there a way for him to use it to check just and ID or OD without having to program
Noob Question
Originally posted by dfiola66Also, keep in mind that manual measurments are ok for locations but in manual mode, the machine doesn't compensate for probe diameter.sigpic
Originally posted by Matthew D. HoedemanDave, is that just on the machine he has or are you talking in general? My machine DOES comp in manual mode, the question is, does it comp properly? It will not for single points, but for planes and spheres it does, and it will comp correctly for lines and circles providing you have the detail set up correctly OR you have measured the plane they are in and change the WORKPLANE in the feature to the plane feature you measured.
Also, my experience with this is without math data...usually just a die section etc. that we have no info on and we need a scan for our records or to remake. Am I missing something?
**for this concern: manual for me means that there is no math data and I'm using feature recognition (probe the points, let the software figure out what I just scanned). Hope I'm not making this more confusing then it has to be.Last edited by dfiola66; 07-13-2006, 02:35 PM.sigpicDF
The "NEW AND IMPROVED" Golden Rule!
Why would you want to sacrifice the accuracy???
With all the discussions about touch speeds and vectors causing problems with hole diameters, I don't ever measure anything on my CMM manually. I ask anyone that wants me to to show me how to control the joystick so that I am at the correct speed and vector for each hit.
Just my $.o23.5 MR2 CAD++/Windows 2000
Originally posted by DuaneSidersWith all the discussions about touch speeds and vectors causing problems with hole diameters, I don't ever measure anything on my CMM manually. I ask anyone that wants me to to show me how to control the joystick so that I am at the correct speed and vector for each hit.
Just my $.o2
I do manual measurements for the engineers quite often with little or no problems. I do set up some sort of alignment when possible and use the part axis button on the jog box for added assurance. We have our own job shop and I am asked to help reverse engineer different parts from machines and gages and robots all the time. I do all of these measurements manually. I have seen other quality techs and engineers try to measure manually and they are very sloppy and try to blame the CMM when their measurements come out bad. I just cringe every time I hear "There's something wrong with the CMM - It's giving me bad results when I know the parts are good." Just got that this morning and I asked them to pull the tool and check it out - There were several broken inserts and broken pockets - But, it was the CMM that caused the feature to check out of spec by 2mm.sigpic
I love that saying " Theres something wrong with the CMM "
It's only does what you tell it and it's only as accurate as the user.
Now if ya'll excuse me theres something wrong with the cmmsigpic.....Its called golf because all the other 4 letter words were taken
No problems manually inspecting w/ Global Image 7107 using careful slow approach with jog box to keep approach vectors as accurate as possible.
We don't do it often because we have a Gage 2000 w/Pc-Dmis (manual)."listening for the last trump... looking toward the eastern sky"
I never have a problem doing manual measurments. On a critical diameter/location, I'll switch to DCC, but the numbers don't vary more than a couple of tenths usually.sigpic Life is not a journey to the grave with the intention of arriving safely, but rather a skid in broadside, totally worn, proclaiming WOW What a ride!
by Dustin S.I just started using the CMM and yes all I had training. We have a brand new Brown & Sharpe One. Purchased the whole package from Hexagon Metrology...
04-22-2009, 10:56 AM -
by George HolzOur Excel 9-12-9 with version 2009 MR1 is very inaccurate when checking parts in manual mode. When reading a fixed gage pin, for instance, you can set...
07-01-2010, 06:10 PM -
by J. LuskOk, its been a while since I've been on here (not running a CMM... floor inspection/ gage calibration.)
Its a very long story, but I'm trying to...-
11-17-2010, 10:09 AM -
by littlejoeI lost my job as a CMM programmer/operator after several years, doors closed back in June. Seems to be the way for many shops here in northern Michigan....
10-31-2007, 12:03 AM -
by OctopussjumpAny suggestions for a new CMM that would be kept in a climate controlled QC office and would have the ability to be programed with PC-DMIS and run in...
12-19-2007, 12:26 PM -
