WHEN SCANNING I AM GETTING TRAILERS, USUALLY AT THE START OR END OF SCAN. WHEN I REPORT THIS SCAN OUT FOR PROFILE IT WILL SAY IT IS OUT OF TOLERANCE BUT WHEN YOU LOOK AT THE SCAN YOU CAN SEE THAT IT IS A TRAILER OR MORE THAT IS BAD. FIRST, IS THERE A WAY TO JUST DELETE THESE TRAILERS SO THE REPORT SHOWS GOOD. SECOND, IS THERE A WAY TO HAVE THE SCAN SET UP TO EXCLUDE THESE FALSE HITS. I HAVE A .00025" PROFILE TO HOLD AND ALL THE HITS SEEM TO FALL WITHIN THIS RANGE EXCEPT FOR THE TRAILERS AT THE BEGINNING OF MOST AND JUST A COUPLE AT THE END. I CONSTRUCT A SPHERE ALSO OUT OF ALL THE SCANS BECAUSE IT IS A GAGE THAT HAS A SPHERICAL RADIUS OF .0005" WITH A LOCATION HELD TO ±.0005.
SCANNING SP25
Yeah, if you are trying to check a tolerance of 0.00025", then your machine needs to be calibrated, repeatable, and speced to 0.000025". Remember the 10% rule, the measurement device NEEDS to be capable of 1/10 (10%) of the tolerance you are checking to.sigpic
Originally posted by Sean HarrisIf you are using 3.6 or above construct a filter set and select remove outliers. If you are using 3.5 or below try to change your start, stop points until the outliers are gone.sigpic
PCDMIS 4.1, 3.5mr2,
by jonasi am running a scan that i am profiling to plus or minus .0002. i am getting a little bit of probe err in what appears to be 3 distinct locations when...
02-18-2010, 04:39 PM -
by giantslayerHi everyone,
We have a six lobe cam that we have been making that we were using a template to check the profile of the lobes. Our customer...-
07-17-2017, 04:21 PM -
by JeeperG'day folks,
I am having an issue with linear open scanning. As you can see on the screenshot, the probe does not follow the profile around...-
07-07-2019, 05:53 PM -
by CONSTRUCTi have a dovetail feature that i am scanning as though it was on a comparator. there are ten seperate planar areas on this dovetail with ten seperate...
08-21-2012, 03:48 PM -
by BKT79Is it all possible to set settings somewhere in PC DMIS to be able to see your scan line along with the upper / lower tolerance. I have a customer that...
Channel: Tips & Tricks
06-24-2014, 08:52 AM -
