When a model is rotated on a couple of axises and is brought in the probe is not normal to part. Is there an easy way to determine these angles so the part setup adjustment can be made quickly? Appreciate any feedback. Thanks Gang.
Probe Attitude
Originally posted by Gary Fitzgerald View PostIs there an easy way to determine the angles for the F5 > Part/Machine > Part Setup? What do you think Roberto?
The only "easy" way to get an "off-angle" part to show the "correct" probe angle is to at least get an alignment done on it for use in offline mode or online mode. The first alignment (of however many you need, minimum of 2 IMO) does not "need" to have "good" probe angles. In fact, as long as you never shank out on the shaft of your probe, the angle makes no difference at all, as long as they are calibrated....
I am not sure if you can put in "incremental" angles in teh F5 option, without looking (and my machine is running right now) all I can remember is that you can make "whole" axis changes (Z+=X+ and so on).sigpic
I know that it is only for Graphical representation and really dosen't have to be totally precise. I find in cases where my approach is tight and I need to square away my tips and probes off line the closer the better. It does take decimal degrees. My usual deal is to tweek until its there including some preliminary alignments. Fun Fun Fun. Thanks for the feedback Matt & Roberto. FYI lately the world seems to have an attitude. :-) ~~ BIG SLAP ~~Last edited by Gary Fitzgerald; 09-01-2009, 09:46 AM.sigpicThanks a Millionth
by BoomerProgramming offline........
1. imported model and it is rotated / oriented diffrently than I want
2. F5 - Part / Machine...-
06-20-2008, 04:04 PM -
by Sammus761Today, as I went to qualify my probe before running a program, when I chose "mark used" for angle selection, the angles selected did not match...
02-22-2017, 10:33 AM -
by JCLASTOUTLAWMy experience is free state is only as good as the setup and part. Fixed datums on a gage/fixture is only as good as the certification and the clamping...
07-16-2009, 12:11 PM -
So I only received 4 days of training before getting thrown to the wolves with cmm and pcdmis...
My probe is not showing the correct location...-
03-18-2015, 03:15 PM -
by StonemanI'm a newbie to PC-DMS and forums so here goes...
I import a CAD file. How do I change the probe orientation. Now the probe looks upside down......-
09-01-2010, 05:48 PM -
