Wondering what process to use for a best fit alignment. Using UG CAD model to check some small parts that are finish cut before heat treat. Performed a manual alignment, then went around outside of part and took several points on each side, recall these points to Best Fit alignment with equal weights. Then perform T deviation hits in the same areas after the Best Fit alignment and it still shows a shift in the part.
Using 3.5MR2 CAD++
Any ideas?
Using 3.5MR2 CAD++
Any ideas?
