Does anyone use a Sheffild machine with a MP-30 controller & PC DMIS software? And If so how did you get you'r part thermister to work for temp comp? All the machine thermisters seem to work fine.
Temperature Compensation
No I do not. But I have a lot of experience with supposed temp comp. I never saw these thermo couples work right. The problem is that they only correct for linear errors and when temperature changes, you machine does not only linearly expand, it bends too. These angular errors completely everwhelm any of the good that the sensors give you linearly. My advice: do NOT use it! The only sure way out is to get your room at 68 degrees.
Sorry, not much help. But I am talking from long and bad experience here. If anything, be very very careful with temp comp!
Jan***************************
by NMC_CMMGood Morning all,
I just had a question about using Temp Comp - do you have to have a material coefficient for your machine axes? If so,...-
08-19-2009, 09:08 AM -
by DeWain HodgeWhen using temp comp on the parts how long does the sensor need to be on the part before it reads the temp? If I use zero delay I've noticed I get temp...
10-06-2010, 11:08 AM -
I've been looking for a MM4 guru but haven't had any success so I thought I'd try my luck with the PC-DMIS forum Gods.
My superiors want...-
04-13-2010, 10:18 AM -
by DaddyBlutoOK, I have always been in well controlled labs and I still am, but we have an FAA audit coming up. My boss wants me to know how to use the temp comp for...
08-14-2008, 06:20 PM -
by RavenmaniacGood morning,
I've just received the low down that the "imperial command" in our company now wishes that our cmms be tested and...-
05-16-2007, 11:11 AM -
