How inhibit command TIPA0...
  • How inhibit command TIPA0...
    I´d like to know how I make to inhibit command TIPA0... when I use "IF_GOTO/". Because PC-Dmis executes this command before for then executing the next one.
    enascimento
    If I understand your question correctly, you want to know how to stop PC_DMIS from indexing your probe when you use a "IF_GOTO/" command
    Can you post the part of the program you are having this problem with so we can look at it?
    Kevin
      PC-DMIS will change the tip angle to whatever is the current angle at the point the program jumps to. I get around this by inserting the desired tip angle at some point before the jump-in line. I'm guessing you are using a GOTO/LABEL command. You might try doing the tip change on the line before the label, then copy/paste the tip change after the label for piece of mind.
      HTH
      v2013 MR1, v2015.1
      B&S Global 544, 555
      Mitutoyo A504 w/PC-DMIS
      Since 1994
      (Advice from my dad.)
