I HAVE AN INTRIGUING PUZZLE THAT MAY BE A HEXAGON ISSUE. I HAVE A KNUCKLE THAT SITS 90 TO MY PROBE. AT A0B0 THE STYLI POINTS TOWARD THE PLUS Y. I USE THIS SAME SET UP ON OUR OTHER MACHINES. WHEN I CALIBRATE, IT DOES NOT RECOGNIZE THE CORRECT DIRECTION. IF I AM AT A0B0 IT WILL WANT TO START FROM THE REAR OF THE SPHERE TO CALIBRATE. IF I CHANGE IT TO A0B-180 IT WANTS TO START TO CALIBRATE TOWARD THE FRONT OF THE SPHERE. I PLAYED AROUND WITH THE PROBE SETTINGS CHANGING FROM 90 TO -90 TO 0 TO 180 TO EVEN 270, NOTHING WORKED. I THEN WENT BACK TO MY ORIGINAL CONFIGURATION, AND SELECTED JUST THE A90B0, A90B-180 ETC., AND IT WOULD CALIBRATE THESE ANGLES. HAS ANYONE ELSE ENCOUNTERED THIS? I AM RUNNING A GLOBAL 12-22-10 WITH PCDMIS 4.0. YEAH I KNOW, THEY SAID WITH THE SCANNING PROBE, TOOL CHANGER, ETC. THAT I WOULD NEED 4.0 TO BE COMPATIBLE FOR SOME SORT OF CONFIGURATION(?)
KNUCKLE WOES
I WAS READING ANOTHER THREAD ON CALIBRATION WOES AND THERE WAS A SUGGESTION TO CONSTRUCT A NEW TIP, SO I CONFIGURED A NEW TIP WITH ALL THE WRIST ANGLES AND IT RAN THROUGH CALIBRATION GREAT. STILL CAN'T FIGURE OUT WHY THE FIRST TOOK A CRAP ON ME THOUGH. BUT, ONE MORE PROBLEM SOLVEsigpic
PCDMIS 4.1, 3.5mr2,
by Tim HindsmanI need to measure some features on the bottom of my part. I have a M2 knuckle in my inventory that I would like to use. I am running PC-DMIs 2015. My...
09-24-2016, 03:08 PM -
by mdaviesI am new to the PC DMIS software and when we recalibrate tips we do all positions due to moving the sphere. Is this required or is there a way to recalibrate...
12-12-2007, 03:22 PM -
Using PH10MQ facing -x- minus direction on horizontal machine, rotated
to 90, -90, the pk1 is facing down in the -z- plus. Probe keeps calibrating...-
03-10-2006, 12:37 PM -
by B. JacobsI have a question. When I calibrate my probe tips, I thought that A0,B0 should be the first one to calibrate. Then all the other angles will calibrate...
06-07-2006, 08:54 AM -
by ALLEN.usmc22I have had issues on how to calibrate a knuckle at an angle and I know it is possible but I don't think I am doing right? any suggestions? I tried the...
10-24-2013, 11:37 AM -
