Is there a way to dimension basic dimensions other than just letting them show up red without any tolerance. It's kind of an eye sore on the report.
Basic Dimensions
You can have them show with just about anything you want. You can change the headings for what is shown on the report. If you have it only show NOMINAL, ACTUAL, and DEVATION, it should not show up as out of tolerance since there is no tolerance for the point.sigpic
Originally posted by bw_bobI'm running 3.5 mr2 and when you dimension using TP they do not show out of tolerance or red. Are you using TP to dimension
Your right Bob I do have them dimensioned in TP. The powers want to see the Basics on the print out also. Gotta give'm what they want!
Thanks Matt I will fix them. I thougth it was something like that.
Thank you Thank you,
You gotta love it when the customer asks to see the basics on the report. Nothing like defeating the whole purpose of basic dimensions! Basics are supposed to be just that, BASIC! No tolerance! They are supposed to be controlled by the GD&T, but they're too lazy or don't know how to properly read a CMM report. So, of course, we get the short end of the stick due to their short-comings. Yeesh!sigpic GO LEAFS GO!!!
Stay true to your friends, 'cause they'll save you in the end.
-Sam Roberts
Originally posted by Scott AppleyardYou gotta love it when the customer asks to see the basics on the report. Nothing like defeating the whole purpose of basic dimensions! Basics are supposed to be just that, BASIC! No tolerance! They are supposed to be controlled by the GD&T, but they're too lazy or don't know how to properly read a CMM report. So, of course, we get the short end of the stick due to their short-comings. Yeesh!
Originally posted by DevaneyYour right Bob I do have them dimensioned in TP. The powers want to see the Basics on the print out also. Gotta give'm what they want!
Thats insane......they have no tolerance..........LOLsigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by bw_bobThats insane......they have no tolerance..........LOL
I know, I asked twice because I wasn't sure I heard it right. Whatever they want I guess.
Matt I am down at the CMM now and I have another question. Does your suggestion apply to the whole report? I really only want to negate the tolerance on a handful of dimensions. Can I do it on a case by case basis?
Devaney,
place your cursor before the dimension and goto the edit menu, preferences, parameters, and dimension tab. Click OK and it will insert a parameter change for everything below it.I used to be high on life but I built up a tolerance.
Originally posted by Matthew D. HoedemanYou can have them show with just about anything you want. You can change the headings for what is shown on the report. If you have it only show NOMINAL, ACTUAL, and DEVATION, it should not show up as out of tolerance since there is no tolerance for the point.By them they know they are lost and say never mind just leave it where it is. So just to pi$$ them off I ask them so I can take it off the report, and they always say no, if its on the print I want it on the report. Then they usally leave knowing that I know what I am talking about and they don't
Originally posted by kingsld1Another way to go would be to put an extremely high value on the tolerance. Then it would never show up RED.
(Of course then they'll ask where you got the tolerance from)
If you do that and elect not to show the tolerance, deviation, and outol in your report you will have no red and they won't know what the tolerance is.
Now we're on to something.
Thanks
by Ken379128I have some basic dimension that I want to report but they show up in red because there is not olerence's. Is there a way to have them show with out being...
07-05-2007, 12:37 PM -
by DannyrlI get prints covered with basic(boxed) dimensions. Everything I read about GT&T says a bisic dimension should tie back to a feature control frame....
03-16-2006, 03:24 PM -
by metalquest1I did a quick search for this topic and didn't come up with any results, so figured I'd post and see what I can find. Is there a way to report a feature...
03-28-2019, 03:45 PM -
by Sl33stakLets say I have a hole true positioned on a print to say, .5mm. Also on the print I have the X and Y coordinates BOXED.
Now lets say that...-
12-11-2008, 12:44 PM -
by ZafraIs there a way to show the total number of dimensions out of spec at the end of the report? Some of our reports get very large and was curious if there...
03-18-2022, 12:53 PM -
