Issues Importing a STEP file...Then IGES
  • Issues Importing a STEP file...Then IGES
    Ok...So I was importing a 35K STEP file. After what seemed like hours of waiting and PC-Dmis acting like it was in "Not Responding" Mode, my model finally came in. The first problem I saw was, the top plane where Datum -A- should be, didn't come in. There are holes that pass through that plane and it's like you can see right through them. And when I try and get my Z value of that plane (Checking Offline) the value isn't right. I had a guy import it in using Inventor and it looked fine. So what happened to that plane???
    Then, he decided to give me the same model but in IGES format
    (almost 53K) this time. I imported it just fine. But, it didn't have wireframe. So I asked him to save it as wireframe to see what happened. I imported it in, and all I got was wireframe. I decided to try and merge the original "solid" IGES model, with the "wireframe" IGES model. Worked well. Now I have both. But....when I went to transform my origin is where I had my next problem. I tried to rotate the model 90° about the X AXIS. Instead, PC-Dmis thought it would be better to rotate about the Z AXIS. Tried several times, to no avail.
    Any idea on why the model is missing that plane and/or why the transform isn't working right for me??
    You say the STEP file took a long time to import but the larger IGES imported just fine? Maybe you should try the STEP file again after a full reboot. Perhaps you hit a glitch when importing the first time. Sorry, that's all I got.
      My first guess would be a corrupt STEP file. You could always try to have them re-export the STEP and see if that clears anything up. As far as the transform I havn't played with that one enough to help you there...
        Yes the Step File take little longer but not much then IGES , in IGES Setup box , check the Show Trim and check Use "B" Curves and then check the Show Base Surface , process in 3D may be that work good luck
        Always Looking at the Big Picture :D:D:D
        3.7 MR1 CAD++
        4.3 Mr1 CAD++
        B&S (Global 07-10-07) -PH10T/TP20
        B&S (Microxcelpfx) -PH10MQ/TP20
          I do the same thing with wireframe/solid...merge the 2 and then I have more options.
          Try rebooting and then the transform/rotate again.
          I have found that PCD will sometimes get a little "hairbrained" after several CAD operations.
          Lately, it occurs to me
          2017 R1 (Offline programming)
            Why do you need to rotate the model?
              Just tried and it didn't fix it.
              This particular STEP file came directly from our customer. And as I stated in the OP, we brought it in using Inventor and it looked fine.
              I saw on some other threads that you do this as well John. I'll try it again and see what happens.
              I like to have the model oriented just as the datums call out and as it will be on the CMM when ran. I have always done it that way. Just makes it easier, IMO.
                Can you see here how the plane is missing and you can see through these holes?
                http://www.pcdmisforum.com/attachmen...1&d=1249490925
                  What software is the source of that STEP file?
                  Here's an interesting bit of STEP "trivia" for you. I have a customer that sends me step files so I can check his stuff. I see this happen quite a bit on "large" surfaces that have been trimmed. Not on ALL of them, mind you, but on SOME of them. If you turn OFF the "SOLID" the surface is THERE and can be selected and used, but when you turn it solid, it vanishes. It is still there, but only as a very small piece of what it SHOULD be. You can NOT select on the "missing" section when it is a solid, but when you change back to the wire-frame view (NOT to the wire frame, just the not-solid view), you can select on it all day long.
                    jkb_mcg ,check view box for the level section may be you more level to add up , for plane
                    3.7 MR1 CAD++
                    4.3 Mr1 CAD++
                      Ok...I was able to bring the IGES back up and complete my transformation. Thanks John.
                        I'm pretty sure "they" are using Unigraphics.
                          BINGO! Same as my customer. Is that missing surface trimmed? I think so if it goes around those holes.
                            I didn't save it last time, I quit the program cause I got the IGES one to work. So bare with me while I import it again... http://www.fordedgeforum.com/style_e...efault/doh.gif
                              Make sure your tesselation is set to 1 or something close. A really low tesselation could be causing this.
                              --Brian
                              "The best way to predict the future is invent it. This includes your very next action."
                              Support: Hexagon Metrology Support Center
                              Training: Hexagon Metrology University
                              • Willy T
                                Which Import Format?
                                by Willy T
                                Guess I need to import CAD models for PC-DMIS to make it easier on me.
                                The last attempt was IGES - our PC couldn't do the straight IGES,...
                                03-18-2008, 11:55 AM
                              • ProbFlex
                                Iges vs step cads
                                by ProbFlex
                                I understand that STEP AND IGES are two different types of cad software. But how does it effect or make a difference when using it in PC-DMIS?
                                11-01-2020, 01:05 PM
                              • jonas
                                Iges file
                                by jonas
                                I made an iges file in solidworks of a solidworks model, when I import the model into pcdmis the iges model has edges to it instead of round radiused...
                                09-25-2009, 12:42 PM
                              • MrComment
                                Trying to import a Step file.
                                by MrComment
                                I'm using v4.1 or 3.7MR3. anyway PCDMIS hangs when I try to import this step file and the size is about 76MB on disk.
                                Tried updating my...
                                01-25-2007, 01:15 PM
                              • Matthew D. Hoedeman
                                Step Files
                                Any of you know the difference between STEP-AP203 and STEP-AP214 files? I got a file from a customer (IGES) that Pcdmis would NOT import, it would get...
                                10-09-2006, 01:02 PM
