I need to define my probe scr200 changer for my TP200 and I can't find the documentation to do so. Can someone help me find that info?
You can download a pdf file of the manual(s) for the TP200 & the SCR200 from Renishaw.
However Pc-demented has a canned routine for defining the rack.
Edit>Preferences>Probe Changer>Calibrate (tab)
Probe changer support in pc-demon is an "add-on" module to the software. Meaning more $. If you have had the changer working in the past then using the canned routine and perhaps F1(for the help menu), should get you there. If this is a new rack, you may have to get the module. If you bought the rack thru your ******** sales rep, they should have told you about the software module and the cost. (But they are infamous for not doing so, hoping you will cough up more $ once you are in process.) Tell them you expected the car to come with tires when you bought it.
HTH
I just started working at a shop with a Brown and Sharpe CMM running PC-DMIS 4.2 MR1. It has a MCR probe changer, but it is just sitting on the side...
Probe changer is a SCR200 on a global image running PCDMIS 3.7mr2. Operator just came to me & said the probe changer is going to low when it is trying...
