Outside edge of circle (radius)
  • Outside edge of circle (radius)
    I've run into this before, and I'm not sure how to do this. Rather than reporting the center of a circle to another feature, I need to measure from the outside edge of the circle. I know I need to create, say, a line tangent and perpendicular to the circle, but I can't seem to find the right choice when creating a point or line. Any suggestions? Its difficult for me to copy anything, and I'm in a pinch, otherwise I'd post the print.
    J. Lusk
    v Pro 4.2 MR1 release.
    Manual align/ NO CAD!
    Dimension as a distance utilizing the circle options (right side of dialog box) and check add or subtract radius.
    The workplane you are in will be important.
    Lately, it occurs to me
    2017 R1 (Offline programming)
      ...you could try creating a variable offset point based on the measured radius of the circle...
        r u sure
          Or you could pierce the circle with a line and report the distance from the pierce point. Again, workplane is crucial, as is vector of the line. This works great in some applications where subtracting radius does not.
          HTH
            Originally posted by JoBLOCK View Post
            r u sure
            *raises hand*
              How do I do this?
              J. Lusk
                How do I do this?
                meaure the circle, create the diameter variable(it will be the dia/2), construct the offset point (in whichever axis you need) based on that variable...not at the machine, so I cant really help out with actual code right now...
                  Example below:
                    *raises hand*
                    Yes John?
                    Are you gonna slap someone?
                      This is the easiest way, if that is what you are looking for Jerry, why do it any other way ?
                      Jim Jewell
                        No, he raised his hand...cause JoBlock asked if he's sure....Raise your hand, raise your hand if your sure!
                          DOH! That one went right over my head!
                            Isn't that what usually happens to people from Cleveland?
                            Contura Calypso 5.4
