ok...heeere's a fun one........
  • ok...heeere's a fun one........
    this is a nasty part. first of all it's huge. second of all it's huge.
    i'm actually doing pretty well inspecting it. i can get most of the diameters and location dimensions and such but i can't get the 156degrees radius located at E7.
    i've blown it up a little in the second attachment so you can see it better.
    should i use a series of points and combine the two?
    set of lines? contruct a point in between the two lines?
    some suggestions on how you'd go about checkin it would be helpful.
    my other issue is finding the dimension 5x .25 located at D4. again should i use a series of lines or points? i know it's a very involved question but just some simple suggestions would be helpful.
    your momma's so stupid, she thought JUDO is what they use to make bread.
    You just talking about the angled surface ?
    Is this part sheet metal ?
      well yea. i'm not sure how to measure the 156 radius.
      lol no. it's one huge piece of solid aluminum.
        The first thing I'd do is this
        Then I'd use Repro Rubber on both unless you can get the probe in there and the I'd not try to check the radius with the CMM just the angle and for the 5X on the .25 dimension I'd do a line-point distance.
        Contura Calypso 5.4
          what dwade said. The CMM is a great tool, but is not always the best tool for the job.
            The 156 degree angle can be checked by creating two lines and measuring the angle between them. I would just create 4 points that were in line with each other on the centerline of the part. The blend radius is not going to be accurate if the surface finish is not real good should be √16 or less because of the short angle.
            On the second callout I would create a line on the outside on the centerline and create a point over it on the inside then just do a distance between the point and line.
            Type in your zeros to make sure you are on the centerlines but use the model for the vectors. that is the easiest at least to me.
            Tolerance challenged ... Living in the world of unseen lines.
            • Perry Fisher
              creating lines
              by Perry Fisher
              I need some help from the gurus. Attached is sketch of a "D" shaped hole I'm trying to check. The 2 60° angles are what I need to report. The...
              11-09-2007, 12:17 PM
            • AuRules
              Checking Radius
              by AuRules
              Got a tricky one fellows, how would you go about checking these 2 radius I have pictured in the attachment I need size and location. The bottom part of...
              09-12-2013, 01:11 PM
            • JLHUTT
              Diameter at the end of a radius?
              by JLHUTT
              Help, I have a part that is about 3.5" long (round) with an I.D of 1.5" in diameter. On one end of the I.D. there is a radius of 1.5",...
              01-03-2008, 08:14 AM
            • quality2214
              Radius
              by quality2214
              I currently have (for a lack of better term) bowl shaped cavity that we will be injection molding into. There are no tooling prints for it. The engineering...
              11-16-2006, 11:01 AM
            • sluggo9000
              Partial radius readings
              by sluggo9000
              In many of the machined parts I have to check, there are always several
              radii that are 90' or less. I usually use auto circles with the proper...
              09-09-2009, 09:10 AM
