Explain this! As you can see, I reported the X and Y location of CIR2, then reported the true position of CIR2 in the X and Y axes to CIR1, but the reported X and Y have changed. How can this be? I was aligned to CIR1 in the X and Y already when I reported CIR2 the first time, so measured X and Y relative to CIR1 in the true position should be the same.
A10 =ALIGNMENT/START,RECALL:A7, LIST= YES
ALIGNMENT/TRANS,XAXIS,CIR1
ALIGNMENT/TRANS,YAXIS,CIR1
ALIGNMENT/END
DIM LOC20= LOCATION OF CIRCLE CIR2 UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
X 0.000 0.283 0.283 -0.025 -0.025 0.000 ----#----
Y 0.000 0.283 0.283 -1.113 -1.113 0.830 <--------
END OF DIMENSION LOC20
DIM LOC21= TRUE POSITION OF CIRCLE CIR2 UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
AX NOMINAL +TOL -TOL BONUS MEAS DEV DEVANG OUTTOL
X 0.000 -0.529 -0.529
Y 0.000 -0.958 -0.958
DF 16.930 0.170 0.170 0.152 16.912 -0.018 0.000 ----#----
D1 16.930 0.170 0.170 0.098 16.858 CIRCLE CIR1 AT MMC
TP MMC 0.800 0.479 2.188 -118.919 0.909 -------->
END OF DIMENSION LOC21
ALIGNMENT/END
