Graphical Analysis
  • Graphical Analysis
    I did a scan on an OD and I need to print out a graphic of the form. I constructed a circle from the scan, dimensioned it with graphic analysis on, but I can't seem to get it onto the report. What's the solution?
    Global Advantage 12-22-10
    TESASTAR M SP25 4.3mr2
    check the "screen captures" box for your report window?
      It's checked, still nothing.
        use circularity dimension function
        report command analysis (Alt-I,R,A short cut)
        select circularity feature from list
        create graphical analysis
        Something like that. I hope this helps.
          and the
          "ANALYSISVIEW/LOC6,,"
          line is in the program?
            That worked IH. Thanks!
              cool... insert/report command/analysis click "view window" radio button then set your view as you want it, then Options/create analysis view command.
