Version 4.2
Sheffield Discovery's
I have a couple programs that worked just fine a week ago and now are causing me trouble. The situation is exact for both. I am getting the message "probe tip not defined" and it is in red. So I try doing the F9 thing and I tell the program to use a different probe instead and that works fine
(1mm). It just doesn't recognize the original probe(1.5mm) There is no data for the 1.5mm probe.
This is the weird part........If I do a file/new and select the original 1.5mm probe as my choice, everything is there still.
So I thought I could out-smart the CMM by doing a file/new and pick the 1.5and then copy/paste the code below the probe stuff from the original program into the one that lets me select the 1.5mm probe. It looked good until I closed the program and then re-opened it and got the error. Any ideas? By looking at old posts, I see things about the probe files but I dont understand it. I have never built a new probe so if the answer is down that road I will need some help. Thanks people. All of your help is invaluable and I hope that one day I can contribute.
Duane
Duane
