Why DCC alignment won't take over
  • Why DCC alignment won't take over
    Here is what I did before: manually aligned the part and changed the manual to DCC in program and run the program again the machine will automatically align the part. I actually change the threoratical values in the program to make the alignment more acurate. Today, I have no idea why, even after I changed the manual to DCC, the machine still asks me to do the alignment manually?
    Here are the first few lines of the program.
    File Header
    STARTUP=Start Aligmnet
    Load Probe--PH10-2MM
    Load Tip--T1A0B0
    Comment--Make sure nothing in the fixture
    Manual/DCC Mode (This is where I change btw manual and DCC)
    Fly Mode
    Please help and thanks in advance
    Can you post more code than that please
      File Header
      Load Tip--T1A0B0
      Fly Mode
      DON'T change a MANUAL to DCC, do a MANUAL then do a second one, in DCC.
        +1 what Matt sayeth
        Starrett RGDC 4028-24 :alien:
          http://www.pcdmisforum.com/showthread.php?t=3139
            I'm glad I'm not the only one requesting this James. I agree with you, Admin should make it a requirement to fill this info out when you join.
            http://archive.perfectduluthday.com/...dead-horse.gif
              It was "done", at least the software specific stuff, a couple months ago or so, BUT, anyone who signed up before then was not required to do so.
                Oh ok. But it still looks like NEW members don't have it on there.
                  Maybe it is like Pcdmis "updates", works for awhile then quits?
                    Sounds about right to me.
                    ADMIN please look into this!!!
                      OK, I can do what your guys suggested to do a manual alignment first and DCC alignment second. But I did change manual alignment after the first time and it worked. Now it won't anymore.
                      Here is the alignment section of the program:
                      File Header
                      STARTUP=Start Alignment
                      T1A0B0=Set Active Tip
                      Manual/DCC Mode
                      Fly Mode
                      PLANE1=Measured Plane
                      Move Point
                      CYLINDER1=Measured Cylinder
                      Move Point
                      POINT1=Measured Point
                      Move Point
                      Bolt=Start Alignment
                      Manual/DCC Mode
                      BTW,
                      Do I have the user ptofile now? I thought I filled them out when I registered the site.
                        File Header
                        Manual/DCC Mode
                        Fly Mode
                        Move Point
                        Move Point
                        Move Point
                        Manual/DCC Mode
                        BTW,
                        ...can you post the real code...not that "flowery, sugar-coated stuff"?
                          That's my problem. The computer which runs the PC-DMIS is not connected to internet, not even to the network. I did copy the program to a USB flash card. But I can't read it on my regular computer (the one I'm using now) as it is .PRG file, not to cut and paste. How to do it then?
                            save it in Notebook or NotePad as a text file....
                              ...and it should look something like this...
                              PLN1       =FEAT/PLANE,CARTESIAN,TRIANGLE
                                          THEO/<13.9567,8.3945,-29.5384>,<0.0002361,0.0001645,1>
                                          ACTL/<12.9828,4.9497,-29.5415>,<0.0057215,-0.0002297,0.9999836>
                                          MEAS/PLANE,4
                                          HIT/BASIC,NORMAL,<17.8344,7.6289,-29.539>,<0.0002385,0.0001535,1>,<10.6847,4.1225,-29.5283>,USE THEO=YES
                                          HIT/BASIC,NORMAL,<17.8345,9.2558,-29.5396>,<0.0002385,0.0001535,1>,<10.6847,5.8162,-29.5285>,USE THEO=YES
                                          HIT/BASIC,NORMAL,<10.0783,9.2239,-29.5374>,<0.0002385,0.0001535,1>,<15.2809,5.8159,-29.5542>,USE THEO=YES
                                          HIT/BASIC,NORMAL,<10.0785,7.4695,-29.5375>,<0.0002385,0.0001535,1>,<15.2808,4.0441,-29.5552>,USE THEO=YES
                                          ENDMEAS/
                                          COMMENT/OPER,NO,CREATE A LINE ON THE BACK OF THE GAGE
                                                         ,TAKE THE FIRST POINT -X AND TAKE THE SECOND POINT +X
                              LIN1       =FEAT/LINE,CARTESIAN,UNBOUNDED
                                          THEO/<9.4782,9.7411,-29.5969>,<0.9998536,-0.0171123,0>
                                          ACTL/<11.6616,6.1715,-29.5995>,<0.9999994,-0.0011336,0>
                                          MEAS/LINE,2,WORKPLANE
                                          HIT/BASIC,NORMAL,<9.4786,9.7411,-29.5969>,<0.0171123,0.9998536,0>,<11.6616,6.1715,-29.5995>,USE THEO=YES
                                          HIT/BASIC,NORMAL,<18.4271,9.588,-29.5968>,<0.0171123,0.9998536,0>,<19.661,6.1624,-29.5995>,USE THEO=YES
                                          ENDMEAS/
                                          COMMENT/OPER,NO,TAKE ONE POINT ON THE +X END OF THE GAGE
                              PNT1       =FEAT/POINT,CARTESIAN
                                          THEO/<20.0069,9.1285,-29.5968>,<1,0,0>
                                          ACTL/<21.1375,5.0176,-29.5995>,<1,0,0>
                                          MEAS/POINT,1
                                          HIT/BASIC,NORMAL,<20.0069,9.1285,-29.5968>,<1,0,0>,<21.1375,5.0176,-29.5995>,USE THEO=YES
                                          ENDMEAS/
                              MANUAL     =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                                          ALIGNMENT/LEVEL,ZPLUS,PLN1
                                          ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS
                                          ALIGNMENT/TRANS,XAXIS,PNT1
                                          ALIGNMENT/TRANS,YAXIS,LIN1
                                          ALIGNMENT/TRANS,ZAXIS,PLN1
                                          ALIGNMENT/END
                                          COMMENT/OPER,NO,GET READY FOR DCC!!!
                                          MODE/DCC
                                          CLEARP/ZPLUS,0.5,ZPLUS,0,ON
                                          MOVE/CLEARPLANE
                              A_1        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-1.5436,-0.513,0.0081>,<0,0,1>
                                          ACTL/<-1.5431,-0.5131,0.0525>,<0,0,1>
                                          TARG/<-1.5436,-0.513,0.0081>,<0,0,1>
                                          SNAP=NO
                                          REPORT VEC=<0.0023396,-0.0024489,0.9999943>,UPDATE VEC=<0,0,1>
                                          SHOW FEATURE PARAMETERS=NO
                                          SHOW CONTACT PARAMETERS=NO
                                          MOVE/CLEARPLANE
                              A_2        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-1.5187,-1.9723,0.0073>,<0,0,1>
                                          ACTL/<-1.5183,-1.9721,0.0526>,<0,0,1>
                                          TARG/<-1.5187,-1.9723,0.0073>,<0,0,1>
                                          SNAP=NO
                                          MOVE/CLEARPLANE
                              A_3        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-10.1167,-2.119,0.002>,<0,0,1>
                                          ACTL/<-10.1162,-2.1189,-0.0012>,<0,0,1>
                                          TARG/<-10.1167,-2.119,0.002>,<0,0,1>
                                          SNAP=NO
                                          MOVE/CLEARPLANE
                              A_4        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-10.1409,-0.6952,0.0025>,<0,0,1>
                                          ACTL/<-10.1405,-0.6952,-0.0011>,<0,0,1>
                                          TARG/<-10.1409,-0.6952,0.0025>,<0,0,1>
                                          SNAP=NO
                                          MOVE/CLEARPLANE
                              B_1        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-10.6017,-0.0019,-0.0662>,<0,1,0>
                                          ACTL/<-10.6011,0,-0.0665>,<0,1,0>
                                          TARG/<-10.6017,-0.0019,-0.0662>,<0,1,0>
                                          SNAP=NO
                                          MOVE/CLEARPLANE
                              B_2        =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-2.4974,-0.001,-0.0642>,<0,1,0>
                                          ACTL/<-2.497,0.001,-0.0645>,<0,1,0>
                                          TARG/<-2.4974,-0.001,-0.0642>,<0,1,0>
                                          SNAP=NO
                                          MOVE/CLEARPLANE
                              DAT C      =FEAT/CONTACT/VECTOR POINT,CARTESIAN
                                          THEO/<-0.0001,-0.5172,-0.0637>,<1,0,0>
                                          ACTL/<0.0017,-0.5171,-0.0644>,<1,0,0>
                                          TARG/<-0.0001,-0.5172,-0.0637>,<1,0,0>
                                          SNAP=NO
                              DAT A      =FEAT/PLANE,CARTESIAN,TRIANGLE,NO
                                          THEO/<-5.8299,-1.3249,-0.0492>,<-0.0006285,-0.0004827,0.9999997>
                                          ACTL/<-5.8295,-1.3248,0.0257>,<-0.006243,-0.000077,0.9999805>
                                          CONSTR/PLANE,BF,A_1,A_2,A_3,A_4,,
                                          OUTLIER_REMOVAL/OFF,3
                                          FILTER/OFF,WAVELENGTH=0
                              DAT B      =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
                                          THEO/<-10.6017,-0.0019,-0.0652>,<1,0.000105,0>
                                          ACTL/<-10.6011,0,-0.0655>,<1,0.0001308,0>
                                          CONSTR/LINE,BF,2D,B_1,B_2,,
                              ABC_ALIGN  =ALIGNMENT/START,RECALL:MANUAL,LIST=YES
                                          ALIGNMENT/LEVEL,ZPLUS,DAT A
                                          ALIGNMENT/ROTATE,XPLUS,TO,DAT B,ABOUT,ZPLUS
                                          ALIGNMENT/TRANS,XAXIS,DAT C
                                          ALIGNMENT/TRANS,YAXIS,DAT B
                                          ALIGNMENT/TRANS,ZAXIS,DAT A
                                          ALIGNMENT/END
                              ...use the # icon that is located to the right hwen post a response.
