Good Morning Everyone,
I had a situation with our Engineering Group and VP. A callout on a print has "profile of a surface to datums AB&C, with a tol of 1.5mm". The part is a rail about 550mm in length. The callout is refering to the edge surface. Basically the straightness of the part. Ok, this is the question.
If I use the profile option in pc dmis, then I have to take several points, create a line and profile dimension the line. The software will only allow a positive value. That would be 1.5.
However the group pulled the GD&T examples out of their files and according to that, then I should dimension all the points taken and tolerance them as
±.75mm.
What is the correct way of doing this????????
Thanks in Advance,
A.Gore
±.75mm.
Thanks in Advance,
A.Gore
