WISH LIST
  • WISH LIST
    Well, I have a new item I would like to see added to Pcdmis. As part of the pattern function, I would like to be able to rotate or mirror around a point that is NOT X0Y0Z0. I know I can reset my alignment to something else, then do the rotate/mirror, then go back, but it would be much easier if you were allowed to type in the point about which to rotate/mirror.
    ANOTHER WISH for inclusion in Pcdmis:
    The ability to dimension a variable directly: INSERT ~ DIMENSION ~ VARIABLE ~ then select the variable to report, with the ability to tolerance and everything, instead of requiring you to create a generic feature using the variable.
    i would like to be able to change the size of the 'points as spheres' from with in the program instead of from the setting editor.
      I wish they would include a seat at class or throw in a CD reviewing all the latest updates with your SMA agreement. Instead of charging another $350 for an "Update to 4.0 DMIS"
      BS
      Windows 7
      Pc-Dmis 2015
      Global Performance 7-10-7
        I would like to see vector delta return - Avail and Virtual Dmis had this
          I wish we would upgrade.....
            I wish you could edit programs in WORD.
            James Temmen
              i wish i had a keg cooler next to my CMM.
                i wish i had $1,000,000 in my 401K
                Southern Man don't need him around anyhow!
                  Wish list
                  I wish i had a motorizied head and a keg cooler and ac and some pretzells.
                  Global Status 777 PC-DMIS 2014
                  Windows 7
                  ever stop to think and forget to start again?
                    Being able to set the point shere size for each program would be a graet addition. I like to set the sphere size to match the tolerance zone of a profile. Then everyone (toolmakers, die designers, customers) who look at the graphics screen printout get a visual assessment of the condition of the part. If the point sphere is 'touching' the CAD surface it's in-tolerance.
                      what is vector DELTA?
                      I know what vectors are but not Delta
                      please explain
                        I wish they would get our sma straightened out so we can go to 3.7 mr3. Dang paperwork snafu.
                        And if there was a keg cooler by my cmm productivity would go way down! The room would be over crowded and there would be no place to put the parts.
                        Screw It. Let's Ride
                        2011 MR1 Cad ++
                          i wish we had some good looking women working here.
                            Winston, maybe if your probe would stay up you would get your wish. Then they could tap your keg for you.LOL
                            James Temmen
                              How about a true "offline" seat with PC-DMIS. (and not charge $3000 for it) If I'm only using one seat at a time, what difference does it make how I use it. We have Quindos and PC-DMIS on one of our machines and it would be great to edit a PC-DMIS program while a Quindos program is running.
