Runout and Total Runout
  • Runout and Total Runout
    No idea if anyone can answer this or not.
    I am having a problem with runout and total runout.
    When I measure features off a combined datum, for example, Datum "AB" I am continuously getting ridiculously high readings. I mean, we are talking WAY off. Like giving me a reading of .030 runout on a part that I know is no worse than maybe .0002.
    I know I am programming something wrong but it's just not registering with me what it is.
    Any help appreciated.
    Thanks.
    PC-DMIS 2009
    Brown & Sharpe Global Image 9128
    PC-DMIS 3.7 MR3
    Brown & Sharpe Global Image 575
    Thanks.
    Are you leveling to the co-primary datum?
      How are you constructing the A-B datum?
      sigpic GDTPS - 0584
        No, I am leveling on the "A" Datum.
        PC-DMIS 2009
        PC-DMIS 3.7 MR3
          I create the "A" Datum then the "B" Datum (Both circles along the same plane) and create a line running through the centers of "A" & "B". This line becomes the "AB" Datum.
          PC-DMIS 2009
          PC-DMIS 3.7 MR3
            ...it has to be a 3-d line....
              take a plane in top of part ,alignment and level to Z+ then take a concentricity of the two circles just to see if they are with the .0002" yuo find before , your datum -A-is inner circle can you post a partial print or the code
              Always Looking at the Big Picture :D:D:D
              3.7 MR1 CAD++
              4.3 Mr1 CAD++
              B&S (Global 07-10-07) -PH10T/TP20
              B&S (Microxcelpfx) -PH10MQ/TP20
                Yep, that was it!
                This was officially my "duh" moment.
                I knew that. Therefore, I made it a 2D line...DUH!
                Thank you for the reminder! You rock!
                PC-DMIS 2009
                PC-DMIS 3.7 MR3
                  Yep, that was it!
                  Don't forget the customary slapping of the forehead - boy if I had a nickel for everytime I had a brainfart moment programming I'd be able to buy my own CMM
                  Originally posted by Ironhoe
                  I got something under my sporran for you, take care of it and you got my vote.
                    +1...glad I could help Gomes
                    • JoBLOCK
                      Runout
                      by JoBLOCK
                      Roughly speaking: runoutx2 = concentricity right?
                      Example. round part. I am chucking on the OD checking the runout of the ID
                      03-30-2009, 02:55 PM
                    • VONDY
                      RUNOUT vs CIRCULAR RUNOUT
                      by VONDY
                      In 3.5 We Had The Runout Dimension, But In 4.1 They Call It Circular Runout Dimension. I Have A Part That I Am More Or Less Checking The Face Runout...
                      10-04-2006, 12:34 PM
                    • John Kingston
                      Total Runout
                      by John Kingston
                      I have a part with /TR/.010/A/B/. -A- is the plane I am leveled to in Z and my Z origin. -B- is a diameter perp. to Z. -B- is also my X,Y origin. The...
                      05-29-2007, 03:12 PM
                    • ADAM WALLACE
                      total runout queston
                      by ADAM WALLACE
                      I know this is more a GD&T question more then a cmm question. Is it a ligit to call two plane surfaces that are to be parallel to eachother as a total...
                      11-08-2013, 02:58 PM
                    • WolfMan
                      runout
                      by WolfMan
                      I have a callout on an ID runout .002 -B-. Datum B is another OD.
                      So, the roundness of the ID is .0000. The actual location is X.0 Y .002....
                      04-24-2016, 09:00 PM
